Question about Jensen VM9410 Car DVD Player
Having trouble with screen
Everything works its just that my screen shows the color green meaning the color white is now green.. i have no idea how it became like this. me and my gf was watching a slide show she made for our one anniversary. it was working fine untill we played it again and notice the color was diffrent.. like i said everything works but the screen just shows green when its soppose to be white
3 Suggested Answers
SOURCE:
simplemitch
  • 752 Answers
SOURCE: My TFT display screen only shows white. (white, not blue)
Sounds to be defective. All white is not normal under any conditions.
Posted on Sep 11, 2007
  • 239 Answers
SOURCE: do you have to to hook the deck up to somethin to
as soon as you open the screen you should see something come up
Posted on Aug 12, 2010
The screen has more green color color, the sky now shows up as lite green and the whites, show-up as real lite green.
you try to set the color tones,,when the last time you have it clean. by cleaning the crt,s and the morr in side the set ?
Oct 21, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Digital Lifestyles 42" LCD HDTV
How many hours has the tv been used ... approx... as this will reveal further solutions..
Jun 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
I get a code d09 does that mean my regulator is bad
No it does not, it means there is an issue with one of the speedometer inputs, see the chart I attached to help you understand.
SPEEDOMETER TROUBLE CODES
CODE - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - peedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit
Jun 14, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Dec 27, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Toshiba 50h81 2001 rear projection hdtv ONLY SHOWS GREEN! PLEASE HELP!
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Toshiba 50H81 50" Rear Projection...
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
SONY KP53HS30 rear projection TV screen suddenly turned blue....
The blinking 5 times is an error code meaning that the white balance has a failure. And because you are experiencing a blueish screen then your problem lies in the circuit of the blue picture tube or possibly the blue tube itself is starting to go bad.
C-Dog
Feb 05, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung D415 white screen
i have same proble with u? how to fix it?
Oct 13, 2006 | Samsung SGH-d415
Jensen VM9410 Car DVD Player Logo
71 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
