Hi,this is karimul islam.i am from malda.i have some technical problem about dvd writer ,procer fan.my procecor fan is sounding all of time when i using notebook.and my dvd writer is can not load or write any dvd ,cd.......my warenty period is till 1|1|1ccr to 3|3|3ccr..
sla:1|1|ccr to 3|3|3ccr
product:>laptop
MTM NO:77613AQ
MODEL:3000Y-500
SERIAL NO: MA5ZY8P
UPGRADE FROM 1|1|CCR TO 3|3CCR , PART NO: 12X6240
please give me immidiate response to solution my problem....and please give me my case id no.
thank you very much sir........
This issue is common to CD/DVD-ROMs. To fix this issue, visit my technical page at reyfrancisbasa2.blogspot.com for a graphical step-by-step instruction.
Let's make sure that Nero is not causing the problem. Try this: -Insert a blank CD or DVD -Find a file that you want to burn to disc -Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled) -Open My Computer, double click on your recordable drive - You should see your file ready to be burned to disc - In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
There might be a lense problem in your cd dvd writer,if you are burning dvds check whether it is combo or dvd writer, because combo drive only reads dvd but not burning...
or attach your writer to any other system to know whether there is a problem with your writer or with your burning software.
if it runs ok with other system ,means there is a problem with your burning software i.e nero 8...
------------------------------------------- low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not Regards :
I am Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue. I would like to provide my suggestions on the issue. I working in HP as technical Support, so I am sure that I can tell you best information available for Your PC.
I see that you are using HP Compaq dc7600 Small Form Factor PC , and you are looking for install of new HP dvd1040i-b DVD writer.
Yes, you made a right choice. You can either go for HP dvd1040i-b DVD writer. or HP dvd1040i 20x Super Multiformat DVD Writer. Both DVD's machines are best. They suite and fit in your PC.
For your convienience, you can buy HP dvd1040i 20x Super Multiformat DVD Writer from below HP link:
Hi, well the short answer is NO. You cannot use DVD's in a CD Writer at all. So the simple answer is to get some CD-R and copy the files to them. OR get a Combo DVD/CD writer and install that as well.. and then you can use both..
