Question about Compaq EVO D510 CMT P4 2.5/20GB/256MB (268899999) PC Desktop
Desktop problem desktop noise and low performance
  • Lamar Ryan
    Lamar Ryan May 11, 2010
    Can you clarify what you are asking ?
  • 67 Answers
Check your processor fan it might have dust on it. your pc seems to be heating up. clean processor fan properly. all noise should go away and the perfromance will come back to normal
Posted on Mar 27, 2009
Tip
Computer howto get better Performance
If you have low memory here is a little trick to improve your computer.
If you right click on my computer and click on properties.
And then click Advanced.
And then click on Performance Settings.
And then click on Best Performance.
This will increase Performance by at least by 10%
on Jan 09, 2010 | Computers & Internet
Tapping noise camsharft
check the cam lobes are ok. If damaged then there will be noise and low performance
Nov 09, 2013 | 1991 BMW 3 Series
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
Haier A/C CPR10XC7-L
The Haier ESA410J-L is part of the air conditioner test program at Consumer Reports. In our lab tests, air conditioner models like the ESA410J-L are rated on multiple criteria, such as those listed below.
Comfort:This is how well temperature and humidity are controlled at the low-cool setting. The best performers held temperatures to within one-and-a-half degrees of the setpoint.
Indoor noise low:This judgment of indoor noise at the low-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Indoor noise high:This judgment of indoor noise at the high-cool setting combines an objective measurement of noise level using a decibel meter with a subjective assessment of noise quality (how annoying or grating the particular sounds were).
Jul 22, 2012 | Televison & Video
Noisey clutch no drop in performance 2ltr tdci c-max
Hello, This can be a noise from a failing clutch throwout bearing. Depending on wear, the bearing can have a noise from a high pitched whine to a low rock-crusher growl. You may also get noise from an out of adjustment clutch, but as you noted, you have not had any difference in performance.
Some clutches use a hydraulic slave cylinder which could produce a sound like the hydraulics in your brakes. I believe this unit shares fluid with the brake reservoir under the dash. If you have noticed oil on your shoes or pants, or an oil sheen inside the cars' carpeting, the reservoir could be leaking.
Jun 07, 2011 | 2004 Ford Focus
My dell optiplex gx620 fan is creating a noise what to do
Three possible conditions of fan noise.
A condition of functional computer component parts
first, an overloaded memory due to several programs installed on the desktop bacground
second, a disk in the driver compartment generating fan energy to cool the system. Caused during movie displays using the computer disk drivers, or burning disks with the disk driver. Third, an extensive use of the computer requires more fan energer cooling capacity.
solving fan over tasking
1. free up the computer memory requirements by removing malfunctioning software programs
2. perform a computer defragmentation located by clicking START, PROGRAMS, ACCESSORIES, SYSTEM TOOLS, selecting the options disk defragment
a. defragmenting redistributes files into spaces producing an effeccient memory function requiring least fan capacity.
3. perform a computer malfunct programs cleanup by clicking START, PROGRAMS, ACCESSORIES, SYSTEM TOOLS, selecting the options of disk cleanup
a. the disk cleaning removes remnants of fragmented files making performanc effective requiring least fan generate energy
conditions of disfunction condition in a component part
1. a broken component of the computer system impeding the fans effective performance
a. a foreign object in the fan compartment causes loud noise
b. a broken fan due to over heating
c. a manufacturers condition of prior computers that performed on fan cooling rather than heat sunk dispensing and obsorption
contact expert technical support
Dec 20, 2010 | Dell OptiPlex GX620 PC Desktop
Vfr 400 has poor performance at low RPM, any
Try a compression test of your cylinders ,and check your valve clearances .
Apr 26, 2010 | 1988 Honda VFR 400 R NC24
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Computers & Internet Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
