Question about Philips 23PF5320 23 in. HD-Ready LCD Television
No picture on Phillips 20in TV
I believe my grandson turned the brightness down until there is no picture, but I can't see the menu to bring the brightness back up. Can anyone walk me thru the menu so I can see it that is the problem. I change the channel and lower or raise the voice, but have no picture. I did buy a new adapter on e-bay. With the old adapter I got nothing, so I bought a new one.
  • Philips Master
  • 5,568 Answers
Your previous adaptor may have been damaged by the failure of an internal component in the set.
Look at your LCD screen from a shallow angle to see if you can spot any 'ghostly' images on the screen when it is turned on and has audio present. If you can, then either the fluorescent backlight has failed or the circuit that produces its high voltage. I've yet to see a modern set that even allows the brightness to be turned down so far that no image is present.
Your grandson may be 'off the hook.'
Posted on Feb 22, 2009
I changed my lock code on my Samsung intensity and now I can't remember it...please please please help me........?
I hate to bring the bad news, the only way to have access to your phone again is to do a hard reset. If you have pictures or anything else saved on your micro sd card, take it out, perform the hard reset then pop your sd card back into the phone so hopefully not everything is lost.
To perform a hard reset...
1.Turn off phone
2.Hold the volume down button and press the power button
3. Hold them down until the backdoor menue comes up
4. Use the volume down button to get to the reset
5. Hit the (I believe) the camera button or the power butoon to confirm
Dec 14, 2012 | Cell Phones
I in mi aoc tv lcd l22w89 the option picture blocking, contrast and brightness to 100% and I can not change
In the menu system there is a reset (I believe it's all reset, or reset all...something like that) which should fix the issue.If not, leave the TV unplugged for 4 hours and plug it back in then turn it on.
Nov 26, 2011 | AOC L22W898 22 in. LCD TV
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
I have changed the settings somehow on my camera and don't know how to get it back to it's original setting, the quality of my photo's seem quite ***** like and very bright.. anyone know how to change it...
Press the MENU button to bring up the Record mode Menu. You can use this shortcut menu to quickly change image resolution, reset all settings to factor defaults, enter Panorama mode, enable Picture+Sounds, enable Silent mode, change the scene mode (when set to the SCN position on the mode dial) as well as enter the Setup menu.
Hope this helps.
Jan 12, 2010 | Olympus FE-230 Digital Camera
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
How do you change the brightness ?
Pressing the menu button will bring up the picture menu. This will show you the options for brightness. If turning this up doesn't fix the problem, the TV will need to be repaired.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 06, 2009 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
Mar 04, 2008 | Acer AL2671W 26 in. LCD Television
Closed captioning issues
Hit The PIP Button On The Remote Until It Says CC OFF
Feb 15, 2008 | Philips 25PS40S 25" TV
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
