Question about Epson RX620 All-In-One InkJet Photo Printer
Will not print cd covers
Brandnew epsom stylus photo r360 will not print cd covers says wrong media type how do i get over this
  • david pearson Jun 16, 2007
    actually printing onto cd message comes up wrong media type cancell print how do i get right media type
If using epson print cd click on print then make sure your printer is selected and media type says cd/dvd,then click on manual print in the same box,another box will appear
make sure it says your printer again then click on properties select text and image or whatever you want,below that where it says paper options in type make sure it says cd/dvd make sure it says this 1st or it will give you an error for the next bit,
then above that it will say source select cd/dvd then click on ok all the way back and hopefully this should print on your disk,
i have to do this everytime now since i installed 2 printers on my comp
hope this helps i know its long winded
Posted on Oct 02, 2008
I don't have an rx620 but I do have an R800. I had problems getting it to print directly on my cds too. Mine had a tray that you set the cd into. So there are three steps to this process. 1. Put the printer in CD mode. I do this by sliding the paper ejection tray (the tray where the paper goes after it's print) up. This is weird and I had a hard time at this part. The entire tray slid up on my printer. 2. Put CD into the CD alignment platter and then the platter easily slides into the printer. Line up the arrow on the left side. 3. Push the paper button. The printer then grabs the platter and moves it around. Your printer should be ready to print cds. Hope this helps...
Posted on Jul 10, 2007
  • Rich Lee Aug 03, 2014
    Actually printing on CDs
    Genius:
  • 2,985 Answers
Describe what YOU call CD covers? There is an anomaly here. Are you simply printing onto a4 paper for jewel case inserts or do you mean actually printing onto the CD.
Posted on Jun 16, 2007
I keep getting the message"the
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Mar 11, 2011 | Epson RX595 Photo All-In-One Printer
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Epsom R220 printing wrong colours
Print a nozzle check pattern then clean the heads until nozzle check pattern returns to normal. If you are using cheap **** compatible inks, throw them out and get some genuine stuff to run in the cleaning routine. Cheap **** compatible ink makes the situation worse when cleaning.
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Delete print queue in epsom stylus c46
Hi
Go to control panel, click on printers, look for stylus c46 icon, right click and cancel all documents. restart your computer afterwards.
Thanks for using fixya!
Oct 31, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper Selection on my Epsom R1800 & R800 using a MAC
Hmmm, I print from a Mac to an Epson Stylus Photo R1800 and a smaller HP inkjet one. What application are you trying to print from? And are we talking about the R1800?
Oct 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printing on cd/dvds
you have to change the tray before you turn the unit on.
then check the paper path settings that you are selecting in the preferences. it should say CD/DVD on it, as well as the media type
Sep 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Software
Go to www.epson.com, select your machine type, model and OS from the drop downs and then confirm.
You should then get the option to download the available software like PIF tool and easy print module.
Jun 08, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Epsom stylus photo printer 360
Make sure there is enough room for the CD tray to move through the back of the machine. Describe fully exactly whit is is you are trying to do.
Jun 17, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
179 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
