Question about Magic Chef 31000 Gas Kitchen Range
Magic chef oven igniter will not glow.
Replaced the glow bar, still will not glow, no voltage to the glow bar, although the broiler glow bar will light, so the fuse is OK. Where do i check next? There are no codes displayed.
  • 640 Answers
The gas vavle..check for contiunity..just follow oven ignitor wire down ..onthejob
Posted on Jan 19, 2009
Kenmore Oven
I am sure you will just have to replace the oven igniter (glow bar) These will crack and not let any power through the oven valve.
Nov 27, 2013 | Magic Chef Ovens
Oven will not light. the glow element comes on but the burners will not ignite to heat the oven
You could have a weak glo bar, that is common or the main oven gas valve could be bad.You have to trouble shoot and find out which it is.If you happen to have a seperate broiler in that range that has a separate glo bar you can use it in the lower oven to see if it will open the gas valve.Hope this helps.
Jun 03, 2011 | Magic Chef Ovens
My Magic Chef model 9112XUB wall oven will not light. It has power and gas but will not ignite.What can I do to fix it myself?
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
Dec 19, 2010 | Magic Chef 31100 Gas Kitchen Range
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Jul 23, 2009 | Kitchen Ranges
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven Won't light anymore
when your oven was working did it "click" to start? or do you have a glow bar style ignitor. if yo u have a glow bar ignitor chances are thats the issue. if your oven would click to light then there might be a few issues on that but just like you top burners you should be able to light the oven with a long match and or barbecue lighter
Nov 11, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven, Broiler will not ingnite
ok try this turn the bottom oven on count to thirty then smack the safty valve with the plastic end of a screwdriver its the square box with two wires on it that the burner tube goes to underneath if it lights replace it
May 26, 2008 | Magic Chef 31100 Gas Kitchen Range
Oven won't light
Hey im sorry to hear that...
I fix many ovens., however not really familiar to yours...
However instead of searching for thermostat, try looking for either thermo-couple, falme flaiure device or falme safety device these are the three main termonologies used....
Hope this helps......
Im sorry cant provide you with a full on solution ... but my guess is that your is probably a thermocouple......
Jan 03, 2008 | Magic Chef CGS3760 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
598 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
