Question about Creative Labs ZEN SLEEK MP3 Player
Frozen I plugged my mp3 into the computer, and it froze. i tried to hold down the off button, but it just won't do anything!!! My song name is on the screen, and it has the lightning bolt icon on the battery, like it is charging. I don't want the screen to stay on till the battery dies, because the backlight will die!!! What should i do?
  • bonzo kaufman Jun 16, 2007
    all you do is press the reset button, located on the bottom of the devise, it has a circle around it.
  • Anonymous Nov 11, 2007
    Frozen while on play mode, cannot shut down screen stays lit
Press the reset button once with a pin/paper clip by the usb connection. If that does not work press the reset button again but this time hold the play button until a different screen comes up....then I selected clean up. crzmiggie@hotmail.com
Posted on Sep 24, 2007
SOURCE:
SanDisk Sansa froze on song screen, wont unfreeze
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 02, 2010 | SanDisk Sansa E280 MP3 Player
Screen froze on cover flow. nothing now works.
If u hold down the center button and the play/pause button at the same time the ipod will restart. Trust me I had the same issue before on my 30GB Ipod Video
Aug 15, 2009 | Apple iPod nano 3rd Generation
Apple Ipod Nano Chromatic Frozen on black screen.
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-8 seconds.
Hope this helps!
Aug 10, 2009 | Apple iPod nano MP3 Player
My Philips GoGear MP3 Player is stuck
Been using this for a few months. Froze up on same song while on vacation last month, and continued to play same song on repeat until battery went down. Now is frozen with "Do Not Disconnect" as it was being charged on my laptop. Attempted to unplug and plug back in and Windows gives DO NOT DISCONNECT!!!!!
I am having the exact same problem!!!!!
Aug 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Ipod 5th Generation Video froze and is now dead
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 26, 2009 | Apple iPod nano 3rd Generation
Screen froze up on't do anything
Try resetting it by sliding and holding power button for about 15 seconds. Go to http://www.sansa.com/support for more troubleshooting and FAQs. Hope this helps and don't forget to rate the answers.
Mar 06, 2009 | SanDisk Sansa Clip MP3 Player
I bought it yesterday and It already froze.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jul 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Ipod 30gb video black
Try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 15, 2008 | Apple iPod MA446LL/A MP3 Player
Sansa disk e 260
I had the same problem with mine freezing. It happened when I kept pressing the back track button (on left side) to go back to an earlier song. It then froze in the middle of a song, couldn't hear the song, the time of the song was frozen, etc., and the unit stayed lit, despite pressing all the buttons. I tried holding down power but nothing happened. I read another person's post that you need to hold it down 15-30 seconds. I did this and it worked, you just have to hold it down until it shuts down, which was about 15 seconds as suggested, could be longer for others.
For me, next time I wont keep clicking the tracks repeatedly, I'll simply go out of the song and back to the song I want through the menu.
Thank you for the good posts. Glad I didn't have to mess with the battery like others....
May 14, 2008 | SanDisk Sansa e260 MP3 Player
After listening to the first song, i flipped to the next and it froze!
There should be a reset button at the back try this, or hold the power button for several seconds and see if it does anything.
If it's just frozen in on mode you can also wait for the battery to die and then try again.
Good luck.
Jan 19, 2008 | SanDisk Sansa e260 MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
65 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
