Question about RCA F31317 31" TV
No power and squealing!
RCA F31317,went out, now no picture and makes loud squeal sound from left rear. I've been told over and over again that it's an easy fix if I know how to solder, I use a solder iron for a living, I just need to be pointed in the right direction. What am I looking for? In what general direction is it at? What does it look like? Any specifics would be great.
  • 203 Answers
There is going to be a wire that is connected to the back of the tube. The item that wire comes from (Flyback Transformer) needs to be replaced. Also, the HOT (Horizontal Output Transistor) is likely bad as well. It'll be a 3 pin unit connected to a heat sync around the Flyback.
Posted on Jun 18, 2007
How do you drain and refill the power steering unit on a 2004 kia Sedona mini van?
you never have to drain it but never let it run dry the loud squealing sound is prob your belt which may need the idler pulley replaced , this is my quess
May 26, 2015 | 2004 Kia Sedona
My 92 chevy blazer is making a loud squealing noise sounds like my belts but its not that I've replaced the belt and the tensioner what else could it be?
Bearings in Alternator, water pump, power steering pump or even a squeal from Vacuum line, EGR diaphram or similar. Check power steering fluid level.
Now when you replaced the tensioner, did you notice more pulleys that were just "there" and not connected to anything? These are idler pulleys and are helpful in routing the belt. They have bearings too!
Pleae rate my info.
Nov 15, 2012 | Cars & Trucks
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Rca f36645
A squealing noise generally indicates that there is something loading down the switching power supply. Generally a shorted component will do that. Without any other information it's hard to tell which circuit could be the culprit. It may even be a faulty power supply itself. Was there any problem prior to this condition? Any odd picture problems, shrinking etc. or sound issues, tuning issues?
Aug 27, 2008 | RCA F36645 TV
RCA TV
Don't mistake hissing sound with a possible high pitched squeal. You probably have a shorted horizontal output transistor. Take it to a service center to be looked at by a professional.
C-Dog
Feb 12, 2008 | RCA F31317 31" TV
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv intermittenly works
the squealing is the power supply off frequency its trying to produce b+ voltage there must be something loading down the b+
Aug 25, 2007 | RCA HD44LPW165 44" Rear Projection HDTV
RCA F31317 31" TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
