I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white they are pink and all the other colors are tinted! The TV works fine otherwise. Since I have had it from 9:00 last night it has stayed the tinted pink. What could be the problem? Trying to figure out what it is before I hire someone to charge me hundreds of dollars to fix it. Thanks
    Champion:
  • 240 Answers
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Posted on Jan 15, 2009
My sony videoscope XBR tv has a pink picture and no control. Also nothing is in enlish.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Aug 26, 2012 | Sony KP-53XBR45 53" Rear Projection...
HI I have a 1998 Sony Videoscope XBR 53 in. Projection TV. When you turn it on the sound is fine but sometimes the picture comes right on and sometimes it can take hours. Can anyone give me some advice....
hello well it's and old tv, my guess it could be capacitors in the power supply or even dry joints on the power supply board, it would be best to have someone with electronic experience to have a look at it
regards
shaun
Oct 06, 2010 | Sony KP-53S65 53" Rear Projection...
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Pink color
Does the tv only look like then when hooked up to the receiver? If it is only then, I would try different cables, If it happens all the time even while not using receiver, then it could be your tint settings on your television.
Feb 04, 2009 | Sony KDS55A2000 55" HDTV
Picture not working on Sony Videoscope
YOU PROBABLY NEED NEW CRTS. UNIT IS GOING INTO IK BIAS SHUT DOWN WHICH MUTES THE VIDEO SIGNAL. YOUR SET IS OLD ENOUGH THAT IT WOULD BETTER TO GET A NEW SET. EST $1300.00 IF CRTS ARE AVAILABLE
30 YR SERVICER
APGONZO
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Home theater reception
you need to unlpug your set and reconnect everything over and see what it does.if that does not work have a tech check your system.your sony recviever is the culprit let that be checked.good luck
Apr 05, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Electro Med Services...
