Question about Hoover Vacuums
Fitting new motor to Hoover ducted CV300CN
How to open up the unit and replace the motor
I opened it up quite easily, attempted replacing brushes, didnt fix the problem so about to order a whole new motor.
Posted on Mar 16, 2017
How do you attach the upholstery tube to the main unit? thanks!
The larger fitting slides into the front of the dirty water tank. Remove the lid and either remove the duct, or lift it and tilt it forward on more recent models. The hose fitting goes in with the opening up, and the "V" shaped end down. After replacing the lid, push the round connector down onto it's fitting under the trap door on top of the nozzle, being sure it is fully snapped in place.
Feb 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Water tube from handle to base unit has disconnected itself
the lower tank lid is removed and then remove the front "duct" panel. now insert the "triangle" end of the hose with the point facing down where the duct came out. re-install the lower tank lid.
Manuals can be downloaded from the Hoover web site
Mar 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Just not sucking like it did
the impella on the motor is clogged and needs to be scraped. dissasemble and its an easy fix from the bottom of the unit
Jan 23, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Wind Tunnel Problem
motor burnout. replace the motor or get a new vacuum
Dec 15, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
159 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
