Question about Lightolier Sunrise Preset Incandescent Dimmer Zp600-br
Flashing lights instead of shutting off
Lightolier preset dimmer. 14 years old. When hit off switch lights flash cannot shut off or dim. Is dimmer broken for good?
  • 37 Answers
14 years does seem like a reasonable life span for a dimmer. My suggestion is to turn the circuit off, take the dimmer out, wire nut the two wires together, turn the circuit on. If the light comes on normally get yourself a new dimmer ($10). Make sure to turn the circuit back off before installing the new dimmer.
Posted on Jan 23, 2009
Lightolier 3 way remote wiring
If you have determined the wiring to be correct, then yes, the remote is probably defective..
According to Lightolier literature, your Lightolier OS600 is called a "strap dimmer". Having 540W on a 600w rated switch is pretty close to the limit (90%) of the switch, and will cause the switch to fail sooner than say a 300w load. The 600w rating of the switch applies only if all the heating sink fins are in place. Often times, when installing in a box with another switch or dimmer, fins must be removed to allow the switch to physically fit. If any fins are removed, the rating of the switch is reduced. Page 30 of the manual shows that a 600w strap dimmer that has a single fine removed is reduced to a 500w capacity dimmer, and if both fins are removed, it is reduced to a 400w dimmer. You may find that you will need a 1000w dimmer to reliably gain control of your 540w load, as it will control 600w even with both fins removed. This derating is required due to the heat created by the dimmer. Heat is a killer for electronics, and solid state dimmers are no exception.
Check out page 32 of that manual. On it, are wiring diagrams for dimmers and switches. I believe your is figure "G" that shows the 120v "hot" (black) connected to the black wire of ALL switches, the yellow wires of ALL the switches are connected together, but are not connected to anything else, the 120v neutral (white) connects to the MASTER white wire AND light fixture white wire and finally, the MASTER red wire connects to the light fixture black wire.
It is also important to note that these switches are for standard tungsten incandescent and quartz halogen lamps ONLY. They are NOT suitable for CFL, Fluorescent or other types frequently found in commercial / industrial buildings such as neon or other gas lamps such as Metal Halide, Mercury Vapor, High Pressure Sodium, etc.
I hope this helps & good luck!
Jun 01, 2012 | Philips Lightolier Onset 600W Incandescent...
Installing a Lightolier 600VA general inductive dimmer switch.
Hi James, I'm an electrician and can help you with this problem.
From what you describe, the wiring in the switch box is for a standard, single pole switch or dimmer, and is not compatible with this replacement switch. Here's why: you stated that there are (2) wires in the box, a black and white insulated wire, that once fed a dimmer switch. Common wiring practices would suggest to most electricians that the white wire is the 120 volt "hot" supply and the black is the switched leg - or output of the switch to the fixture.
The replacement inductive dimmer switch is not a standard switch. It is designed to control inductive loads - or motors such as a fan. It does not simply control the flow of current - but actually uses a small amount of electricity to do this. This means it needs a complete 120 volt circuit consisting of a neutral and hot wire; and wire for the output of the switch to the motor. A total of insulated 3 wires. You have only two.
If you have a neutral in the box, you can use the switch if wire like this:
120 volt "hot" to the switch Black
120 volt "neutral" to the switch White
120 volt load wire (to motor) to the switch Red
The switch Yellow should be taped or capped off and is used only in a three way application.
The "arm switch" cuts power and the wheel is used to set low speed setting. You can see the info sheet here.
As mentioned above, this switch is used to control a motor - not a light. The same way a dimmer is used to control a light - not a motor. If you do not have access to a neutral in the box, you should either install one or, use a different switch. There are motor speed control switches that do not require a neutral wire and cost under $25.
If you need to control both light and fan there are products that are installed in the canopy of a paddle fan that will do this for under $50 and are operated via a wireless remote that can be secured to the wall such as those below:
These can be found at Home Depot, Lowes, and electrical supply stores.
I hope this was helpful & good luck!
Apr 13, 2012 | Lightolier 600VA Preset Inductive Slide...
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
I can't get the yellow wire of the dimmer slider to work properly using a conventional 3way switch on the other side. I do have the slider on the load box. Could it be that i need a Lightolier ZPR-3 on the...
Most of this style lightolier product requires the proper remote such as the zpr3. Leviton illumitech is a similar design, but uses regular 3 way wiring.
There are others out there as well, that do not require the remote.
Mar 05, 2011 | Lightolier 600Watt Preset Slide Dimmer
I would like to replace my lightolier zp600 dimmer to a zpr-3 that has the same wire wiring diagram as a zp600
The zp600 is the master, and the zpr-3 is the remote. With only one location you need to use the zp600. For multiple locations, you use the zp600 at the load side and zpr3's at other locations with all the yellows hooked together, and all the blacks hooked together except the black going right to the light. This hooks to the red at the zp600
Feb 15, 2011 | Lightolier Sunrise Preset Incandescent...
The lights on the dimmer flash and/or brighten and dim on their own. How do we fix this?
For 100% certainty, I would call Lutron's tech support at 1-800-523-9466. They're available 24/7 and can probably troubleshoot it more effectively than through this text-based dialogue. However...
I have three guesses...
1) Check the minimum load. The minimum load for those products is about 40-Watts. If there isn't enough lamp wattage pulling electricity through the dimmer, the dimmer may not have enough juice to keep itself powered up... and then shut down (hence any flashing you may see). If the issue only happens when the lights are at full (or close to full) brightness, then that's most likley your issue. To solve, either increase the lamp wattage, or replace with a dimmer that contains a neutral wire such as the MAELV-600M.
2) Check the load type. The dimmer's are rated for incandescent & halogen. If these are LED or CFL lamps, you are going t see issues. For dimming performance, either convert the lamps to incandescent / halogen, or investigate their new Diva dimmer for CFLs & LEDs: DVCL-153P-
3) If neither of those solve the problem, the next guess is to check the wiring. I wouldn't expect this to cause any "flashing" but in the wiring circuit, each device had a blue screw attached to it, and you need to make sure that the blue screws are wired/connected to each other and ONLY to each other - otherwise "automatic" dimming can take place.
But again, the only way to be certain is to use their tech support. I highly encourage you to use that.
Nov 07, 2010 | Maestro Lutron MAW-603-RH 3-way 600 Watt...
I want to wire a 3 way switch with multiple lights between the switches. The easiest route and least wire used is power in at switch then to lights then down to second switch. would i use a 14/3 from...
You have to run the 3rd wire all the way to the switch, whether it hits any lights or not, I have seen electricians pull a single wire in to the box with the 14/2 and that would be the jumper. This will work on any lights, and the lights only need the 2 wires, It is just the switch that needs the 3 wires. Good luck.
Feb 22, 2010 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
Does old Lightolier cause lights to blink. Not
i assume lightolier track lights? loose wire or loose connection either in ceiling or at switch... if they are all blinking then it is most likely the switch.
Jul 31, 2009 | Electrical Supplies
Open Questions:
See all Lightolier Sunrise Preset Incandescent Dimmer Questions
Lightolier Sunrise Preset Incandescent Dimmer Zp600-br Logo
339 people viewed this question
Top Lightolier Electrical Supplies Experts
ken skalski
robert
Steve
Are you a Lightolier Electrical Supply Expert? Answer questions, earn points and help others
