Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice maker not making ice fast enough
Only making about 8 cups of ice every 24 hours
  • sfowler365 Apr 23, 2009
    Not making ice fast enough to keep up with minimal demand.
  • 163 Answers
Hi!!! Also make sure that your freezer section is bet'w 5 to 10 degrees if not then you have a frig problem..If you have 10 degrees or so then you have an icemaker thermostat control problem.You have to buy another icemaker unless you can replace the icemaker thermostat inside of it..Good luck..
Posted on Jan 15, 2009
You should be getting a fresh batch of ice every two hours or so. If it is taking longer than that, then the freezer temp is not going down low enough, fast enough for the ice maker to work properly. Also check to see if the heater element for ice removal is working - if it has burned out the new cubes are stuck in there and it can take a while for them to be freed up so a new ice making cycle can commence.
Nov 25, 2013 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
What is a recipe for this ice cream maker
What make and model is "this" ice cream maker?
Mar 09, 2013 | Ice Cream Makers
Ice maker does not make much ice. I just changed the water filter and reset the ice maker by turning it off. It just makes a few cubes in 24 hours.
Hi and welcome to FixYa. When an icemaker still makes ice but in a reduced capacity it is usually the result of other problems.
Either there is ice build up on the evaproator coils due a defrosting problem that you do not see or the evaporator fan motor is not running fast enough.
Here is a way to find out. Unplug the unit and use a fan blowing into the freezer compartment for at least 2 hours. This is a manual external defrosting that will rid the evaproator coils of any ice build up.
Plug the unit back in. Over the next 30 hours check to see if your ice made result is much more than before the manual defrost.
If this improves your ice made result then you probably have a defrosting problem with your unit.
You did not say if the cubes were smaller or not so I have to assume the cubes currently are normal in size and that water flow and ice maker fill timing are fine.
Feb 28, 2010 | LG LFX25971ST Bottom Freezer French Door...
Ice maker
sounds a liitle to fast actually, its rated for 8 cubes for "harvest"(cycle, and each cycle problably about 1:45, ittl take a while to fill the bucket , perahps 36-48 hours. once filled though maintains good normal use levels.
Oct 29, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Viking VCSB423 side by side icemaker
You could empty the bucket when full for the days leading up to a party and save the ice somehwere......or buy an Ice machine
Sep 12, 2008 | Viking VGSC306-4B Gas Kitchen Range
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Gets only cool not cold
Vanilla Bean Ice Cream
makes 1 generous quart
4 egg yolks
2/3 cup sugar
2 cups half-and-half
1 vanilla bean or 2 teaspoons vanilla extract
1 cup whipping cream
In a bowl, beat the egg yolks until blended and mix in sugar. Heat the half and half, stir into the egg yolks, and pour into the top part of a double boiler. Split the vanilla bean and scrape its seeds into the cream and add the bean as well. Place over simmering water and stirring constantly, cook until the mixture is custard-like and coats the spoon. Remove from heat and refrigerate until cold, or several hours. Remove vanilla bean. If using vanilla extract, stir it in at this point. Just before ready to churn; stir in the whipping cream. Freeze according to directions for your ice cream freezer.
Sep 03, 2007 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
891 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
