Question about Panasonic DMR-ES10 DVD Recorder
Some discs will not finaliize.
In each case they are Sony DVD - . Some finalize and play OK but some will not. The machine also makes a grinding noise during the attempt to finaliise. So far, this has only happened when I try to transfer from one particular VHS cassette. Having not finalised, it then displays "the disc is only available for playback. It will also not erase any items (thus behaving as if it has finalized the idsc - but it has not)
Your help would be appreciated
Regards
Robert
  • hi_bandwidth Jan 15, 2009
    My unit (approx 1.5yrs old) is exhibiting a similar grinding noise and also has problems finalizing discs. It doesn't really seem to matter what type of disc is in the drive (I believe it's a pending hardware failure).
    Problem Solver:
  • 5 Answers
Turns out the rubber disc grip on the spindle simply needs to be cleaned (using an alcohol wipe). This is the part that holds the disc firm while it's spinning...the noise and failed disc reads comes from this rubber getting dirty and allowing the disc to slip. Total time to fix including disassembly was less than 15 minutes!
Posted on May 01, 2009
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Can't play finalized DVDs dubbed from VHS on other Sony DVD players or PC
It sounds like the disc were not finalized properly. Are you sure the player finalized the discs?
Apr 08, 2008 | Sony RDR-VX500 DVD Recorder/VCR
The model # is CECHG01. Cosmetically, the system is in good shape, with some scratches/scuffs. It powers ok. You can access system menu. But when I insert a disc, the bluray drive makes some kind of...
The system makes noise. When using the system in a location where heat can build up, such as in an enclosed AV cabinet, on carpet or a cushion, or near a wall (within 10cm of the wall), the internal fan will rotate rapidly to reduce the system's temperature and this may generate increased noise. Move the system to a location with good ventilation. Depending on how a disc is being used, such as when copying an audio CD to the hard disk or starting software from a disc, disc noise may be louder than normal. Furthermore, some software may cause more disc noise than others
The Blu-ray Disc (BD) or DVD cannot be played, or the picture is distorted. When outputting DVD content or PlayStation® format software in standard definition (SD) resolution, only discs recorded in the NTSC standard can be played. If the system is connected to a VCR, copy protection encoding on some BDs and DVDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly. You may also see a similar occurrence if using a combination TV/VCR unit. If the BD or DVD does not match the region code set in the system, it cannot be played. For details, see "Region codes" ( page 50). Some DVDs are preset with parental control restrictions. Enter the password that was set in (Security Settings) to temporarily increase the parental control level. If you record video content on DVD-R, DVD-RW, DVD+R or DVD+RW media using a device such as a DVD recorder, you must finalize the media before playing it on the PS™ system. Finalize the media using the recording device. Some BDs are preset with parental control restrictions. Enter the password that was set in (Security Settings) to change the parental control level. The BD may be disc-locked. Enter the password that was set when the disc was created. See also the notices under "Playable discs" ( page 49). Certain BDs cannot be played. To play commercially available BD video software, the encryption key for AACS (Advanced Access Control System) may need to be renewed. To renew the key, you must update the system software.
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award your Accepted best answer.
Jan 10, 2011 | Sony Playstation 3 (PS3) Console
U88 displayed on dmr es15 panasonic dvd recorder. cant play ,wipes discs ,makes grinding noises
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Nov 14, 2009 | Panasonic Televison & Video
Sony dvd handycam finalize problem
If your discs are rewritable, you could try putting your discs in your computer. Try opening the folders and try to open all the files. Some of the files may be your videos. If it opens your video player and plays your videos, wait until it plays everything to make sure that all your data were recorded in the disc. Copy everything in your computer and remove your disc. Try playing it again and if it works, then it's already ok. When you are planning to use it again, make sure that you format everything in the disc.
Jun 11, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
PS3 Not playing discs
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Apr 08, 2008 | Video Game Consoles & Games
Mini dvd's not recognized by pc
I had a similar issue at first... needed to ensure that I had the Sony Picture Motion Browser Software downloaded to the system and then it was ok.
Tom.
Mar 14, 2008 | Sony Handycam HDR-UX1 DVD Camcorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
360 grinding noise and unplayable disc
Crack open the DVD case and see whats going on and try fixing it yourself. OR Buy a new drive off of eBay and transfer the firmware key over from the old drive too the new one.
Sep 20, 2007 | Microsoft Xbox 360 Console
Panasonic DMR-ES10 DVD Recorder Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
