Question about LG Shine KE970 Cellular Phone
Speaker phone I am having trouble downloading the nuser manual also I can't find out if my shine has a speaker phone feature
After you select your contact and press the call button it becomes speaker on/off button. p.s. how do you like the quality of your speaker? Mine distorts at volume leve 6.
Posted on Jan 15, 2009
GE Cordless phone 26938ge1 d
After looking through the instructions sheet I can tell you there is on speaker phone feature in the handset but you buy an optional headset unit that plugs to the side of the handset to make the system hands free. But that is not same as having speaker phone.
see instructions after downloading from GE Cordless Telephone User Guide ManualsOnline com
Aug 08, 2014 | GE Lands Phones
Does this phone have speaker phone, and if so how do i turn it on?
Yes, there is a speaker option. Holding the phone in your hand look down to the lowest row of buttons - below the * 0 # buttons. There are four buttons: from left to right they are SPEAKER; PAUSE/REDIAL; REMOVE/MUTE; and, INT (INTERCOM.) Pressing the left/SPEAKER button one time turns on this feature. Pressing this button turns OFF this feature. Hope this was helpful.
May 11, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
I have a NEC DTU-16D-2 phone system. The Speaker
Press Feature and then 1. This will turn on the MIC.
Apr 20, 2010 | NEC DTU 8D-2 Corded Phone
Got paint into speaker of LG cu720 shine
I suggest you google: Schematics for LG Shine CU720 cell phone and follow the links provided.
The answer is there. There may or may not be a cost for the Schematics.
May 30, 2009 | LG Shine CU720 Cellular Phone
Unknown Phone on Lincoln Navigator
It means your phone is activated somehow. Cellular Phone NOTE: The audio system does not operate when the portable cellular phone is in use because the audio-mute feature will mute the audio system when a call is placed or received. Portable Cellular Phone Features
The portable cellular phone system is available only with the P100i audio unit and has the following features:
  • hands-free operation
  • radio muting while phone is in use
  • radio displays the phone number, signal strength, and call timer
  • radio can be used to dial stored numbers and adjust hands-free operation volume
For more detailed information, refer to the User's Guide.
  • Entering ACM Self-Diagnostic Mode.
  • ACM (Audio Control Module) Self-Diagnostic Mode
    NOTE: To enter the Speaker Walk-Around Test or ACM self-diagnostic mode, the ACM must be turned on and in radio tuner mode (AM/FM).
    ACM self-diagnostic mode can only be entered while in the Speaker Walk-Around Test.
    1. To enter the Speaker Walk-Around Test, press the ACM Preset Buttons 3 and 6 simultaneously.
    1. The Speaker Walk-Around Test stops at each speaker and applies a different tone to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the ACM in the following sequence: RF, LF, LR, RR, SUBWOOFER I, SUBWOOFER II.
    1. The Speaker Walk-Around Test automatically continues and tests:
    • the antenna and displays ANTENNA II, for five seconds.
    • for a speaker short. If a short is present, SPKR SHORT will be displayed.
    • for the CD/DJ. The ACM display will show NO DJ if not present. The Speaker Walk-Around Test will end and the ACM will return to its previous setting.
    1. ACM self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the ACM Diagnostic Trouble Codes (DTC) Index. If the system is OK, SELF PASS is displayed.
    • Preset button 2 = View/Clear continuous diagnostic trouble codes (DTCs). NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > button to view the DTCs retrieved. Refer to the ACM DTC Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for the software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    Controller Description Radio Display Example Main Main micro software version MAIN ##.##.## CDSP CDSP micro software version CDSP ##.##.## ADSP ADSP micro software version ADSP ##.##.## Auxiliary Auxiliary software version AUX ##.##.## CD/DJ CDDJ software version DJ ##.##.## CD Changer CDR software version CD ##.##.## Tape Deck Tape Deck software version TAP ##.##.## RSC Rear Seat controller software version RCP ##.##.##
    • Preset button 5 = DISPLAY TEST. This test will light all the ACM display segments for five seconds, then turn all segments off. When the test is complete, DISPLAY TEST is displayed on the bezel.
    1. To enter these tests, press the preset button desired while in the Speaker Walk-Around Test. This will abort the Speaker Walk-Around Test and start the selected test.
    1. To exit ACM self-diagnostic mode, turn the ignition switch or ACM OFF.
    1. If the concern remains and the fault is not detected, proceed to Symptom Chart to continue diagnostics.
    the module is under the floor console. Do you have the phone user manual.
    Apr 03, 2009 | 2000 Lincoln Navigator
    My sony ericcson w600i volume is too low even when the volume bar is at the highest.
    Use the speaker phone feature. Speaker phone can be selected after call is answered. See manual or google phone model and "Speaker Phone" on net.
    Mar 02, 2009 | Sony Ericsson W660i Mobile Phone
    Cant find speaker phone feature on my Motorola Razr V3 cell phone
    Yes, This phone does have a speaker phone setting.
    When in a call it should be the top right button on your keypad.
    Dec 17, 2008 | Motorola Mobility RAZR V3
    Motorola W450 Speakerphone problem
    when the phone is dialing the number you want to place a call too, then you will see the speaker icon in the right bottom corner of the phone then select it and your speaker will be on.
    Nov 23, 2008 | Motorola Mobility RAZR V3
    Nec DTerm Series i - Feature Light Flashing URGENT
    Thankfully I have found a solution that has worked.
    A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
    To cancel this setting do the following
    Lift the handset or press speaker
    Dial the access code 4 + 2 (set as default)
    Receive confirmation tone and restore handset or press speaker
    I have found the manual at the following link to be the best resrouce ever - very easy to understand
    http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
    Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
    LG Shine KE970 Cellular Phone Logo
    56 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
