Question about Acer AL1706AB LCD Monitor
Monitor shut off and will not come back on
Person using computer before me said computer screen shut off and will not come back on. She restarted the computer and still nothing. However, when you push the power button on the screen itself, you will get a brief flash and you can see the long-in box. Any ideas? I've checked the plugs on the back of the screen- all secure.
  • 1 more comment
  • rcamper Jan 16, 2009
    Same issue happened to me today. Checked all cords and all are secure. When you press the monitor on off button, screen shows and then immediately goes black again. Help! Thanks.
  • don3916w Jan 18, 2009
    1 1/2 year old 22" acer al2223w moniter shows absolutely no signs of life, LED or otherwise. Plugged in multiple outlets and on one other computer. Didn't get lightnening struck, well protected. Any ideas? or is it recycle fodder?
  • JoeTheWhiz Feb 16, 2009
    what if the power lights do not become visible?
    Scholar:
  • 144 Answers
Fmiliair proble, check not the plugs on the screen but the ones on the back of the PC, when the screws are not used the plug sometimes get a little loose and when the monitor gets no signal it will go blanc.
However, power lights on monitor should still be visible.
Posted on Jan 15, 2009
Whyisscreen jumpy and jerky
mcdevito75 here, You can try, shut down your computer useing START SHUT OFF COMPUTER, when computer is shut down double check all connections at the computer and Monitor, also check wall socket. Now! restart your computer, check the controls on the monitor, if you have a button auto press it, this will automatically set your monitor. If all this fails, contact Dell, you may have a faukty monitor. Computer does not control monitor screen except for brightness and volume, problem most likely with the monitor itself.
Jul 03, 2010 | Dell Latitude D800 Keyboard
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Monitor won't turn on
I'm assuming you mean that you've tested the computer using another monitor and that the desktop proved to be working fine. If that's the case then the monitor needs to see a reputable repair person for repair.
Apr 04, 2009 | LG L204WT 20 inch LCD Monitor
Screen is on, but does not appear to be on
The monitor was broken. I returned it to the vendor for replacement. Your tech did not seem to feel it was a monitor problem and only focused on the video card - although I asked him directly regarding his confidence of it being a videio card problem versus being a monitor problem.
I will not use your service again.
Mar 21, 2009 | LG 22" FLATRON LCD Monitor
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Jan 27, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor problem
there is a mosfet inside the monitor IRF630 it may short replace it from technical person or replace yourself if you are technical problem will be solved if not then check dry solder correct it otherwise
some boost capacitor may faulty (nearest the yoke coil )replace it
Mar 22, 2008 | ViewSonic E70 17" CRT Monitor
Monitor randomly shuts off and computer restarts
After you turned it on and the screen shut off, check the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If the computer shut down immediately after the monitor shut off, it might be because of fault operating system. Check with another monitor.
Thank you,
Mar 08, 2008 | HP Compaq FS7600 17" CRT Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
Acer AL1706AB LCD Monitor Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
