Question about Technics SL-BD22 Turntable
Drive Belt - Technics SLBD22 turntable
Greetings, This dinosoar needs a part to make his life complete. Anyone have a good source for a drivebelt for the following: Technics SLBD22 turntable A schematic for how the little devil goes back in would be appreciated as well. Thanks! Peter H. PJHutch@ix.netcom.com
    Sergeant:
  • 274 Answers
Try http://www.vintage-electronics.net/ttbelt.html
Posted on Jul 16, 2007
    New Friend:
Steve W. www.turntablebasics.com I recently ordered and received the correct belt for the Technics SL-BD22. The belt was only $10. (Shipping extra. My shipping was $4) I just finished putting it on and it works like new. Turntablebasics also provide instructions on removing the platter and replacing the belt. Friendly service, reasonable price, and more importantly - it works!
Posted on Aug 14, 2014
LPGEAR>com is where I got my last set of two.
Very fast shipping and e-mails on status as well.
Great source!!
Posted on Sep 21, 2011
I have the same turntable, and while it was working well the last time I used it the belt partly melted and stretched.
I was just about to convert vinyl to cd when I discovered the malady.
If I find a belt source I'll let you know.
email me for updates: beachcitiesdjs@yahoo.com
Mark
Posted on Jan 28, 2008
  • djmarkh Jan 28, 2008
    oh, and once you find it it's laughably simple to install:
    1.lift the rubber mat from the turntable exposing the metal
    surface that turns.
    2.lift the metal wheel, turn it upside down, place the rubber band
    on it, turn the wheel back over, stretch the band enough to
    place it on the little pulley, easily seen through the large viewhole
    on the disc, and viola, it's like your back in 1979!
  • dr2casto Dec 27, 2010
    I found one here: $15.90 shipped usps.
I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT DRIVE AUTOMATIC THAT IS SPINNING TO FAST.
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Apr 03, 2010 | Technics SL-1200MK2 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Nov 15, 2008 | Technics SL-1210 Turntable
Record player belt
Scott, the belt wraps around the bottom of the turntable platter, then put the platter back on your turntable, and you'll have to pinch back a section of the belt and wrap around the brass motor spindle. That's pretty much it!
Good luck.
- OPTiC
TWEAK A/V LAB
Apr 13, 2008 | Technics SL-1200MK2 Turntable
Technics sl-1610 mk 2 turntable
Unfortunately, it does sound like a drive issue. Just so you know, these units are direct drive, so there is no physical motor. It's just a bunch of various circuits which drive the unit, and if any one of them go bad, it will affect your turntable speed. You will need to have this looked at by a service technician to determine which circuit is faulty.
- TWEAK AV LAB
Nov 26, 2007 | Technics SL-1200MK2 Turntable
Technics problems
There is no drive belt on this unit. This is a direct drive turntable. Your pitch control might be on it's way out. Are you getting any sort of unusual speed issues? Or is it just sort of running slower than usual? There is a pot you can adjust under the turntable platter to speed it up a bit, however, this is only a temporary fix. It is listed as VR301 - and is on the main board under the turntable platter - it says PITCH on it. Try adjusting that pot, to see if it does anything. WORD OF CAUTION: Make sure your turntable platter is ALWAYS on whenever you power up your turntable, and if you do any electrical modifications, make sure you always disconnect your turntable from it's power source to be on the safe side. If this does not work, then either your pitch control (which is a variable resistor) will need to be replaced. The problem could also be one of the drive components on the main board, however, this will need to be worked on by a service tech. Hope this helps. - Justin
Jun 11, 2007 | Technics SL-1200MK2 Turntable
Technics SL-BD22 Turntable Logo
1,712 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
