Question about Kenmore 53301 Dehumidifier
Coils freezing up
After the dehumidifier is on for only 5 - 10 min the coils freeze up. Any idea as to why?
    Scholar:
  • 39 Answers
Its likely one of two things. 1) the fan isn't moving enough air through the unit. If there is a filter, clean it. 2)If aire flow is OK and its freezing up on one end of the coil and the other end of the coil is not very cold at all then refrigerant charge is probably low. I know that seems counter intuitive but a low charge in a refrigerator or A/C unit (which this dehumidifier is a derivative of) can actually frost up when slightly under charged. Now if the charge is determined to be low there is a leak somewhere and that leak will need to be found and repaired. It will probably take an electronic leak detector to find it. If the leak is on a section of aluminum tubing in a tight location it may be impossible to repair the leak and that may force you into a new unit. If its on a copper tube it can be fixed. If its on aluminum tubing it can be clamped shut if there is physical access for attaching a clamp and seal. Sometimes a leak pushes out some refrigerant oil at the site of the leak making it a visible spot to the naked eye. Hope these comments are of some help
Posted on Jan 16, 2009
Why do the coils freeze on my zenith zd309 dehumidifier
Coils can freeze if the room is extremely hot. Usually, though they freeze because the path for air flow is reduced. Check input and output grilles and coils for dirt and dust and clean as necessary.
Aug 02, 2014 | Zenith zd309 30 pint dehumidifier auto...
I purchased a new Frigidaire dehumidifier and the coils are freezing up. The basement temp is 64 degrees. Any Ideas? Frank
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Feb 24, 2011 | Frigidaire FDF70S Dehumidifier
Why does my dehumidifier get ice on the coils
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 07, 2010 | Eva-Dry EDV300 Dehumidifier
Dehumidifier coil freezes up
heatman101
Jun 08, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier freezes up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
May 26, 2010 | Goldstar DH5010B Dehumidifier
Coils are icing up
heatman101
May 03, 2010 | Goldstar DH504EL Dehumidifier
My dehumidifier will not stop running coils frost up musty odor from it
there is a freeze stat on the unit it connects to the evaporater coils it is suppose to shut of the compressor unit when it senses the temp is at freezing the idea is that the unit condenses moisture out of the air like your air conditioner for your house or car this part is dirty or malfunctionong
May 01, 2010 | Kenmore 53509 Dehumidifier
The coils are freezing up almost immeadeatly
If the fan is running, and it's above 50°, it sounds like it lost some refrigerant (freon). Note that if it is too cold, a dehumidifier will ice up.
Jan 06, 2010 | Kenmore Dehumidifiers
Same with me
heatman101
Aug 31, 2009 | Goldstar DH5010B Dehumidifier
Humidifier coils freeze
I believe a dehumidifier is supposed to operate in temps above 60 degrees. Even though your house is warmer than that, the air entering the dehimidifier may be getting into that range due to it being on a basement level etc. This is perfectly normal and is not a malfunction with your humidifier.
Your options are to either place the dehumidifier closer to a heat source in order to keep the air which is entering warmer. (I've even heard of someone placing a light bulb in front the unit during winter to warm the air slightly as it enters). Because the dehumidifier's coils get cold in order for it to collect moisture from the air, if they are freezing, giving the unit a rest for a few hours every few hours may allow the coils to thaw in between and prevent them from reaching freezing temperatures while running. You could use a timer to accomplish this, but you'll want to insure that it's a commercial grade timer in order to handle the electrical draw that the dehumidifier requires.
Dec 29, 2007 | Eva-Dry EDV300 Dehumidifier
Kenmore 53301 Dehumidifier Logo
564 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
