Question about Husqvarna Viking 1
Freezing screens, uneven feed of fabric, feed dogs stop working
I purchased a sapphire 870 as an ex-demo model from a dealer in sheffield, after getting home and trying various feet etc decied to quilt a small piece of patchwork, after aprox., 1 hour the screen froze and would only work after I turned the machine off and back on. Then on tuesday and wednesday, thought I would give a further try, the feed dogs are uneven with feeding fabric, stitches gathering together then it will sew correct space and distance for short time and then go back to bunching up and even to stopping altogether and not feeding at al.
5 Suggested Answers
  • 201 Answers
SOURCE: Free Motion Sewing - Jams
I don't have a solution, but wanted to remind users of this machine that it does not do the proper free motion action until you reach a certain speed. This information is on page 26 of my manual (older machine, so page no. might have changed with newer manuals). You can stitch at the lower speeds, but it does not "hover" and allow you to move the project swiftly and smoothly.
If you can sew regular sewing without thread/bobbin issues, then it is probably something to do with how you have set/threaded/used the free motion to cause the stoppage. Make sure you have a sharp (i.e. new) needle of the correct size for your thread, that the bobbin thread is the same weight thread as the top thread. Turn on the Needle Down button. There is a Free Motion setting in the Set menu, but I have no idea what it does. I turn it on anyway, just in case! What foot are you using? If you don't have one of the free motion feet (there are quite a few to choose from!) use the embroidery foot (small clear plastic one).
Pam
Posted on Apr 15, 2008
  • 192 Answers
SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
Posted on Nov 01, 2008
  • 6 Answers
SOURCE: My fabric won't feed on my sewing machine
Your feed dogs are in the down position. Check your manual.
Posted on Jun 18, 2009
  • 152 Answers
SOURCE: I have a Husqvarna Viking quilt 870 sewing
The overload message is usuall due to a bind in the mechanical function of the machine. When the motor has an extra "load" caused by something like a tight belt or dry bearing, it "overloads" the motor and the error message is displayed. It is doubtful your problem is computer related. Either way a trip to your service tech is required. If you continue to sew with it, you do run the risk of possible damage to some other parts of your machine. The computer portion of your Husqvarna is guaranteed for 5 years and the mechanical parts carry a 20 or 25 year guarantee depending on when you purchased your machine. A copy of your bill of sale from a Husqvarna Viking dealer or a stamped warranty card is the proof of purchase needed to obtain warranty replacement of parts. Labor is only guaranteed for 1 year.
Posted on Oct 06, 2009
SOURCE: Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
Posted on May 27, 2011
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
The feed dog is not controling the fabric through,so the fabric is moving sideways.
The feed dog could be one of the two: 1. It is cocked at an angle just slightly or 2. Uneven wear of the feed dog. Replace the feed dog.
Jun 27, 2016 | Sewing Machines
My sewing machine model is B 750 QE. Always starting to sew the lower thread keeps knotting up it drags down the fabric and the cogs come on the screen..So I looked at the instructions and followed the...
1. To solve your knotting problem. Learn to always trap or grasp your thread ends for the first few stitches.
2. When the dogs are down, sometimes you have to grasp and jiggle or turn the hand wheel while re-engaging the feed dogs.
3. It sounds to me as if you aren't making sure that the take up leaver is in the top position before you press the "foot button down" Make sure you press "needle up" before you press foot down. That way the dogs should be in the correct position for you to get the fabric under there and proceed. In the mean time... I would strongly recommend you go back to your dealer and take some lessons. It sounds to me that when you learned to sew... you were not trained the proper procedures.
Oct 01, 2013 | Bernina Sewing Machines
My automatic buttonhole attachment won't make
This is not the problem of the thickness, but of the softness. Fleece will pull unevenly, causing the dogs to simply tug at layers of it in place, instead of moving it. You will have to (GENTLY) assist the dogs in moving your fabric, if your fabric is this soft.
The cause of this is 90% on the fault of the fabric, and 10% on the way the buttonholer foot works. The foot is built to hold the fabric fast in place, with sliding action only permitted by the buttonhole guide. However, this is assuming the dogs can get enough purchase to move the fabric around. Simply put, again, you will have to help the dogs along with this one(you will be able to clearly feel the difference and which way the dogs "Should" be moving at the time when you attempt to, as once it catches in one direction, it is likely to keep going in that direction until the dogs stop.)
Jan 24, 2010 | Singer 7444 Mechanical Sewing Machine
I have the Scandia probably 5 yrs old...feed dog is up but wimpy...not moving fabric....it's sporatic...many times the fabric stops and the needle sews in place and then is will move a little - stitch...
The feed dog motor needs re-calibrating. If recalibrating does not resolve the problem, the feed dog stepper motor may need to be replaced. These tasks have to be done by a certified Husqvarna Viking service technician. Suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 08, 2010 | Husqvarna Viking 1
Feed dogs are not pulling the material back
White sewing machine model 510, feed dog problem; fabric is not moving; I must firmly pull fabric through.
The feed dog is moving; fabric is not.
The fabric is not feeding properly; the fabric goes back and forth. However, the fabric does not continue to move away from me.
The feed dog is positioned up and is not smooth, it feels rough when I touch it with my fingers.
Because I had not used this sewing machine for a couple of years, before sewing, I cleaned the inside with the wire brush that came with the machine.
In an attempt to trouble shoot the problem, I applied varying pressure foot levels and stitch lengths.
Does anyone have any suggestions as to what may be the problem?
Jun 27, 2009 | Kenmore Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
66 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Derek Massey
Natasha Subko
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
