Question about Western Digital Computers & Internet
Western Digital Hard Drive AAK5000
Internal IDE Drive has stopped working. When powered it makes an intitial tone for a a few seconds then nothing. I cant hear spinning or clicking. It is not recognised by the bios and I have tried it with a madgic bridge device on a number of different machines and the same applies. I have tried various jumper settings but still no change. Sometimes I got the drive listed as missing or not initialised in the "disk manamagement of windows" but I can't intitilse it. I have tried a number of software recovery programs but they dont see the drive. It appers dead. Can you advise any solutions so that I could remove the 500GB of data.
  • Graham Alderton Jan 15, 2009
    WD Caviar Blue WD5000AAKB - hard drive - 500 GB - ATA-100
    is the exact model type.
  • 298 Answers
Your HDD motor or PCB (on the HDD) blew
IF it is the PCB, you can jot down the numbers on the connector (look for this pattern: xxxx-xxxxxx-xxx-xx) and googlee for it. If you are lucky, someone selling a WD Caviar Blue WD5000AAKB - hard drive - 500 GB - ATA-100 will look at their PCB and see if the revisions match. BUY the HDD!!
You now have a 50/50 chance to get the HDD working again.....
IF the motor blew, you WILL hose the new board, and end up with 2 bad drives
IF the PCB blew, it might just surprise you and work. I have used this trick to recover data for $$$ on 8,20,60,80,160,200,and 250 WD drives that were out of warranty. Good Luck
The other option is IF the motor went bad, and you will certainly know if you see burned chips on the back of the PCB or hear a loud POP when you try the new one... You only have 3 choices.
1. Send the HDD off to a Data Recovery $ervice (No guarantee here)
2. Send it to WD for a warantee replacement (and forever lose your data)
3. Take off the HDD cover, bridge the Positioner, DO NOT TOUCH anything in there and Manually spin the HDD Platter spindle to EXACTLY 3500 or 7200rpm (depending on drive) with a tiny speed-controlled motor and a tachometer, then plug it into ext USB bridge and your PC and if the motor drive is the ONLY thing bad, the speed sense will engage, and the heads will load and you will have ~20min-2hr before the HDD dies due to contamination of the heads and platters(dust, smoke, pet hair,, human skin flakes, moisture and oxygen) so grab the essential files quick! I recommend Total Commander (Hilight all you NEED (not want - there isnt time) and drag to copy. PRACTICE TC on a good HDD. If you miss a file or folder, you will have to cancel and redo, or wait until all others highlighted are done first. Make a list - stick to it.
I have done this 5-6x so far. Several old Seagate and Maxtor 80Gb and for the larger, I Built a mini clean room, complete with forced filtered heat (hairdryer pulling its air thru a HEPA filter. for motor, I Used an expensive German variable speed dremel-like tool and cheap tach from Harbor Freight.
Good Luck!
Posted on Jan 17, 2009
Wd50000aakb make into a external usb
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.10 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
One short beep one long beep coming from hard drive
..as i know when HDD start beeping ( internal or portable ) that indicate problem with the Hard Drive (HDD)..so nothing you can do it by your self ..
..if the HDD is under warranty from factory you may take it to the store that you buy or nearest Western Digital distributor to claim the warranty...but if it doesn't in warranty..that's mean a problem why?
because if HDD start beeping like you have, the possibility to make it work again is almost impossible that mean you maybe lost the data that you save in this HDD..
Sep 01, 2012 | Western Digital Caviar Computers &...
Western Digital WD800JB internal hard drive. I install it, it is listed in device manager, but not on "My Computer". I have unistalled the device and drivers (IDE primary & secondary),...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 11, 2010 | Western Digital Caviar SE WD800JB 80 GB...
Drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Jun 21, 2009 | Western Digital Scorpio 160GB Internal...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Western Digital hard drive problem
Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
Mar 01, 2009 | Western Digital My Book Essential Edition...
750GB Western Digital HDD won't turn on.
hi.. try to Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
Try mounting the original IDE drive internally, and see if you can read it there. If not, you'll need to send it to a data recovery center...
thank u
Feb 09, 2009 | Western Digital (WDXB1200BBRNN) 120 GB...
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
It dasent stared the warning stop:0x0000007B(0xfbcee528,10x00000000,ox00000000)
please check the IDE cable, make sure it appear as primary drive, if problem not solve format your drive if nothing happen its better to buy new.
Oct 25, 2008 | Western Digital My Book Essential Edition...
Wd external stopped working
The round lights on the front of the drive are actually power off/on button. Have you tried pressing it? I know it's simple, but you never know. :)
Feb 18, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
717 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
