The rubber gasket on the bottom of my baking pan for a morphy richards breadmaker series 48220 has perished and morphy richards no longer do spares for this model. i may need to replace the whole baking pan, but to replace the gasket would be better. can you help please?
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
My machine stopped heating but everything else functions. Can that be repaired?
There is an element in the bottom.
Google
make model element
They appear to be available
Find Bread Maker Machine Heating Element ' eBay www.ebay.com > ... > Small Kitchen Appliances > Bread Machines Bread Machine Parts Finder is the place to find a Heating Element for your breadmaker. Bread Machine Parts Finder has a breadmaker Heating Element ...
Bread Machine Heating Elements - By Bread Machine Parts ...
www.breadmachinepartsfinder.com/catalog/25 Element-ABM300, Welbilt Bread Machine Heating Element ABM300, $9.99. Element-ABM300, Welbilt Bread Machine Heating Element ABM300-1, $9.99.
Bread maker Heating Element ' Bread Machine Parts Finder
www.breadmachinepartsfinder.com/taxonomy/term/696 Skip to main content. Bread Machine Parts Finder logo. Main menu. Home · Comments. You are here. Home. Bread maker Heating Element. Subscribe to Bread ...
Bread Machine Heating Element - Alibaba
www.alibaba.com > Home Appliances > heating > heating element Bread Machine Heating Element, Buy Various High Quality Bread Machine Heating Element Products from Global Bread Machine Heating Element Suppliers ...
What To Do If Your Bread Maker Stops Working? ' Mr ...
www.mrbreadmaker.co.uk/.../what-to-do-if-your-bread-maker-stops-wor... Apr 12, 2013 - Read our guide on dealing with common bread machine problems. ... are colder and the heat element is not working right then your bread will ...
Morphy Richards Breadmaker Parts ' Partmaster
www.partmaster.co.uk/morphyrichards/breadmaker/catalogue.pl?... Morphy Richards Breadmaker parts - repair your Morphy Richards Breadmaker with a Breadmaker spare part from Currys Partmaster. Worldwide and Next Day ...
Morphy Richards 48280 FastBake Bread Machine Heating ...
www.fixya.com > ... > Morphy Richards 48280 FastBake Bread Machine ...heating element for my SDYD 250 bread maker ? After three uses, the unit no longer heats up......I think it is either a bad control board, or a defective heating ...
Breadmaker Spares ' Spares & Accessories
www.morphyrichards.co.uk > Spares & Accessories Buy a Morphy Richards Breadmaker part. Spare parts for Morphy Richards Bread machine.
and a video of how to change.
How to replace the element in a breadmaker - YouTube
How to replace the element in breadmaker
Feb 06, 2016 | Kitchen Appliances - Others
Spelt bread recipe
Grease two 9x5 inch loaf pans. In a large bowl, mix together the spelt flour, sesame seeds, salt, molasses, baking soda and milk until well blended. Divide the batter evenly between the prepared pans. Bake for 1 hour and 10 minutes in the preheated oven, or until golden.
May 13, 2014 | Morphy Richards Kitchen Appliances -...
We want to just make dough
According to the manual, page 23, "H:HH" means "Temperature in breadmaker is too high". The solution is to "Press the Stop button. Remove the baking pan, leave lid open and allow to cool. When cool, put the baking pan back in, set program and start the program again."
If you need a manual, you can download one here:
http://www.morphyrichards.co.uk/Pdf/IB48286.pdf
Apr 19, 2014 | Morphy Richards 48268 Bread Machine
Manual for morphy richards 48200 bread machine
I got one today after emailing Morphy Richards directly,,no problem!
May 16, 2012 | Morphy Richards Kitchen Appliances -...
I have lost my recipe book for my morphy richards fast bake model number 48267
The Instruction Book for your Morphy Richards 48267 Stainless Steel Breadmaker can be found here:
http://www.morphyrichards.co.uk/Downloads/InstructionBooklets/IB48267.pdf
Sorry someone has not responded sooner.
Dec 26, 2010 | Morphy Richards 48268 Bread Machine
My morphy richards baking pan wont stay in place. It clicks into place. I switch it on, then the pan pops back out again.
You may want to try bending those clips out a little so they hold the pan in better. Are they bendable? Be careful you don't over do it. Please me know if this works. If yes, please give a testimonial. Feedback is everything! Thanks
Oct 21, 2010 | Morphy Richards Kitchen Appliances -...
I need a new mixer blade
Here are a few links to your kneading blade / paddle replacement sources:
http://www.espares.co.uk/parts/breadmakers/morphy-richards/48280/p/1097/511/0/412066
Also
The After Sales Division
Morphy Richards Ltd
Mexborough, South Yorkshire,
England, S64 8AJ
Helplines (office hours)
UK 0844 871 0944
Spare Parts 0844 873 0710
Republic of Ireland 1800 409 119
User's manual with recepies
http://www.morphyrichards.co.uk/Downloads/InstructionBooklets/IB48280.PDF
Parts from manufacturers website including kneading blade:
http://www.morphyrichards.co.uk/AccessoryDetail.aspx?Product=48280
Thanks for choosing FixYa,
Kelly
Oct 15, 2010 | Morphy Richards 48280 FastBake Bread...
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
