Question about Samsung DVD-VR325 DVD Recorder/VCR
Fault code I used the same blank dvd"s as before DVD-r 120 min 4.7 1x-8x many recordings. Up came code of ec-0206 cannot be played or recorded, I tried it recording from th tv. Turn the power of & restart, same thing. I tried a different speed, dvd-r 4.7 16x 2 hrs I've recorded before not as many as the previous but a few. A code of ec-0509 came up, same thing turnoff and restart. I get a fault code also when recording from a vhs to a dvd. Having to buy another machine like I did before upsets me, I have many dvd's recorded on that machine because of the format I can't play them. What upsets me It's probably a button or programing to fix it. Thanks for listening. Joe
  • 2 more comments
  • Joe Morabito Jun 17, 2007
    Yes I still need help. I have allready paid, where is the soultion?
  • Joe Morabito Jun 19, 2007
    I have tried several different brands of dvd's believe me I have dvd's up the gazoo. And telling me to record on a computer is not fixing my current problem is it. So far I haven't read an actual guranteed fix it. Makes me wonder why I paid the money for this service. Joe
  • Joe Morabito Jun 21, 2007
    Thanks for the suggestion, it was the first common sense one, but unfortunatly it was not the problem. I checked the protection it was not protected. I tried a disc again to record from the tv, got the same thing ec0509 tried it from the vcr to the disc and got ec0206. I'm allmost to the point of another machine but I'll hold out a little longer. Thanks Joe
  • Joe Morabito Jun 22, 2007
    I hate to be hard guys keep the money but I think if no one knows what the fault codes mean we really can't fix the problem right. I could have saved $ 10.95 and put it towards a new machine so I guess it's not a gauranted fix is it. Thanks anyway Joe.
    Genius:
  • 1,074 Answers
My friend it is best to record your movies or music with a computer.as these DVDS Recorders are not compatible with certain types of dvd disc brand probably try another brand of dvd disc.and see what it does, try the memorex or the TDK.also dont use dvd recorders to record your movies use them to play back.they are problem.good luck.
Posted on Jun 19, 2007
  • Henry  Thomas
    Henry Thomas Jun 22, 2007
    my friend it is best you get a new machine it will help good luck.
  • 944 Answers
Here is the link to the user manual if you need it; http://downloadcenter.samsung.com/content/UM/200510/20051027171803796_VR325_Euro_BM.pdf check page 85 - "disc protection" and see that there is nothing unusual in the settings there - long shot but it may be automatically write protecting the discs. Although I agree with you about Snakehead's comment about PC's, it would be worth taking a couple of the problem discs and checking on a PC if there is anything unusual on them that may be causing the problem - you will have the flexibility there to investigate further. The next thing to try is updating the firmware. This doesn't sound to be the problem but it is free and easy to do so is definitely worth it; http://www.samsung.com/search/search.asp?charset=utf-8&ht=0&qp=&qs=&qc=&pw=755&ws=0&la=en&qm=0&st=1&nh=10&lk=1&rf=0&rq=0&si=1&ct=None&oct=&oq=%0D%0A&fs=&oqqtex=dvd-vr325&bqt=dvd-vr325&th=0&ts=1&selradio_temp=&qt=dvd-vr325&tabpage=3&radio=1&col=download&select=0# The most common cause for this sort of problem in a dvd recorder that is not too old is a dirty lens. There are other possibilities which might be uneconomical to fix, but cleaning the lens is relatively simple and cheap to do. It is hard to see exactly from the manual, but if you unplug the machine and remove the top cover (give it a few minutes before diving straight in) where the dvd tray is situated will either be a simple top cover (usually has a small round bump in the middle and 4 very tiny screws) or there may be a small printed circuit board you need to remove first - not too difficult but you should be careful to ground yourself - wearing no shoes usually works but also ground your hands to the case of your refrigerator or similar. Then remove any screws (usually 3 or 4) and make sure to remember where any wires or plugs go - a photo can be handy. Once you have the top cover off the dvd tray then you should easily access the lens carriage. Try not to move the carriage if possible, although the lens itself will move slightly. Clean the lens with a cotton bud/Q-Tip moistened (not wet) with gin. nothing else works as well or as safely, but give the lens a gentle blow first to remove any loose dust. Reassemble (all screws inside the machine need to be put back before turning on and it is safer to replace the cover) and then give it a try. Hopefully does the trick. Hope this helps - please ask again if you need more help - especially if you are a bit lost inside the machine and can post me a photo i can talk you through what to do :)
Posted on Jun 20, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 23, 2007
    Have you updated the firmware and/or cleaned the lens as discussed?
    These are the first things to try before deciding it is unfixable.
    The fault codes should be listed in the service manual, which is available on this link;
    https://www.manualsparadise.com/ShowProd...
    unfortunately it is also not free - I have searched considerably with no luck finding a free download.
    Let me know what you hbave done and what you wish to do and i can hopefully help :)
SOURCE:
Can't find the DVD's that will record in my Emerson combo VHS-DVD recorder only the Memorex DVD-R 4.7 gb 120 min 4x will work they are expensive
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Contact 'Emerson' which is really 'Funai' at 1-800-256-2487 complain and they will send a disc to up-grade the 'DVD' recorder to accept the '8x' discs which are cheaper, plus Staples has some 8x disc. 50 for $19.95 a good street price, 8x DVD-R generic Staples brand. Get the upgraded disc and go to Staples and get the generic Staples discs. I hope this helps and good luck. Please vote appropriately and leave a message.
Oct 30, 2009 | Televison & Video
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
"Recorded" or "Blank"? this is the Problem!
Check to see what format you are able to play on you Laptop
Sometimes they only work on some formats. Also make sure you are not recording in progressive scan
Jan 21, 2008 | Samsung DVD-R155
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Won't Read blank disc!!
Ok, I talked to Samsung support again today, and they confirm that the firmware update should correct the problem of incompatibility with 1-16x discs. They are going to mail a CD with the firmware update to me, at no charge. They were not, however, able to tell me if the file I had originally downloaded from their website was the same as what will be coming on the CD. Sheesh!!
If I can determine that they are the same file, I will post such info. here later. Otherwise, I would advise contacting Samsung support and requesting a disc.
The phone no. is:
1-800-SAMSUNG (1-800-726-7864)
Mon - Sun : 9am - 9pm (EST)
Apr 12, 2007 | Samsung DVDR120 DVD Recorder
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Samsung DVD-VR325 DVD Recorder/VCR Logo
238 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
