Question about Samsung LN22C350 TV
I have a Samsung LN 22C350 on a boat imported from America to Australia. I have sorted the power supply and have an 110 v generator on board the boat. Problem is tv turns on but no sound and no picture. Could we have different frequencies in Australia ? Is so can I make it work here
    Top Expert:
  • Samsung Master
  • 14,553 Answers
The set should at least light up on the screen and have noise when you turn the sound up---yes, if a North American made set it will be NTSC format and I think your system is PAL, you would likely have no audio and a black and white image at best.
Posted on Dec 19, 2012
SOURCE:
zjut
  • 106 Answers
SOURCE: picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Posted on Jan 01, 2008
  • 2337 Answers
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to [email protected]
Posted on Jan 05, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
circuitworld
  • 335 Answers
SOURCE: Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Posted on Nov 03, 2009
Testimonial: "Thank you. your feedback was appreciated. Theres a lot of value in getting an expert opinion whether to fix or not to fix."
lightnbaby
  • 36 Answers
SOURCE: Samsung LN-T-4665F will not turn on. Red button
Yes! there are 2 capacitors in power supply 5vdc standby out..recommand repalce with 1000uF 25v.
also one at 12vdc out. same with 1000uF 25v.
Posted on Nov 16, 2009
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
My samsung ln-t4671f takes 3 to 10 minutes to turn on. it just clicks,clicks clicks
The power supply board is dying,that the board where the power a/c cord into it.Replaced the power supply board will stable and work as normal again.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | Samsung LN-T4671F 46 in. LCD Television
My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Jun 07, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a Samsung flat panel television, model #LN-T4042H. When I turn the tv on, it sounds like it is turning itself off and on repeatedly for more than 5 minutes before I finally hear the beeps that...
Take ur tv aparts.The power supply board is the board that ur power A/C power cord go into it.U know basic electronic.U have soldering iron,know soldering,and solders?Check all around the power supply board.Look all around the power supply board,check and see find any defective gases leakage capacitors.These dead capacitors alway have bulges or fuff up it top.Replaced these dead gases lekage capacitors will solved ur power problems.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 11, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
My Samsung LN-T2653H is having problems with power
Possible bad(bulged) capacitors on power supply board, and possible bad main board, too.
Apr 18, 2010 | Samsung LN-T2653H 26 in. LCD HDTV
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Jan 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T4665F when powered on picture is ok for 4 secs or less then screen goes black. Sound ok. I think the video is there just no back-light. Following some online advice I replaced the power-supply...
You more likely to need to backlight inverter boards, thpower supply should have 24vdc for the backlight inverter board, the 24vdc power supply get the trun on command from the controller board, that is what should have been checked first. So look for 24v or measure it directly on the inverter board connector pin. The invereter board also has a couple surface mounted fusesYou can get the inverter board here but make sure to match the number: http://www.shopjimmy.com/catalogsearch/result/index/?q=LN-T4665F+&limit=100
Dec 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
I want to operate a LN-S2641D in Australia. I have 240 to 110 Volts transformer but when I plug in to Australian signal it has no colour . I am wanting to use the Samsung LCD as a monitor receiving a...
Go into settings menu on your screen setting and change the PAL/NTSC settings Aust uses a different format to the US. Try "Auto" first if you have that option.
Mar 26, 2009 | Samsung LN-S2641D 26 in. LCD HDTV
Jan 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung 40 inch lcd tv
the issue is with capacitors on the power supply board ,open your TV and look for caps with damage on the top,the caps are 110 volt change them to 120v
and your issue will be gone.
I have done this with four of this kinda of TV and all are working like a charm
Nov 10, 2008 | Samsung LN-T4065F Television
Samsung LN22C350 TV Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
