Question about Sony Xplod XM-554ZR Car Audio Amplifier
My amp works on tuner but switches off when i change it to cd
My Sony XM-554ZR works fine on the radio but when i change over to CD it powers off. Well the light says there is no power.
  • 156 Answers
The remote turn-on wire from your amplifier is connected to a blue wire behind the head unit. That's a power antenna activation wire, so the amp only turns on when the tuner is on. Switch it to a blue/white wire from the head unit instead; that should be the amp remote turn-on output.
Posted on Jun 16, 2007
SOURCE:
2006 Buick Rendezvous cd and xm not working but radio works fine
depends on what fuse. the fuse on the back of the stereo or the fuse in the fuse box? if the one in the fuse box it should show you on the cover that you opened to get into the box. it should say stereo. now if your looking for the one on the back of the stereo you will have to take the stereo out and on the backside you will find a fuse or two. good luck
Dec 07, 2013 | 2006 Buick Rendezvous
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
When it is in tuner mode the subs ant speakers work but when u swich it to cd only the subs work
on the factory radio conection you need to power up the factory amplifier, for any rason is conected to the power antenna wire (blue), you need (blue/white) from your aftermarket radio.
Sep 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
SONY Xplode 52WX4 CD player - no manual.
Go to sony.com and go to support enter your model #.
Nov 25, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Cant get amp to work
there are two nobs on the back of the amp they have to be turned inorder to ajust the woffer vol. make sher its not in power safe mode that will be a red light insted of a green one
Sep 16, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod xm-554zr amp
try disconecting ur battary for 2 min and try it again
Jan 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Does not accept cd
I guess is your using a CD that was made from a blank one.. Try putting in a CD that you didn't burn.. and see if it works Some CD players does not place burnt CD's Hope i helped cya buddy
Aug 11, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Problem accepting CD
Remove the face plate and see if there's a small "reset" button underneath that can be pressed with a pen tip.
Aug 10, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Amp
The remote wire from the amp is connected to a blue wire behind your head unit. This is a power antenna activation wire; it's only active when the tuner is selected. Switch the remote wire to a blue/white wire at the head unit.
Jun 20, 2007 | Sony XM-D6000GTX Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
114 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
