Question about HP Photosmart D7160 InkJet Printer
My Photosmart D7160 is telling me to turn my paper over as it seems to think the print side is on the back - how can I override this? Thank you
  • webmail Jan 16, 2009
    It worked (I use a Mac). Thank you very much!
    Scholar:
  • 144 Answers
When you want to print something do it via file, print, and a screen should appear with the printers available but also with the properties button. Click the properties button. On the appeared tab with the settings there should be a check box to automaticly select the paper based on sensors. Uncheck that box, click OK, OK and it will not prompt you during this job. If you want to permanently switch this off, go the the same properties tab via start, configuration, printers and scaaners (in XP).
If you use the printer to print direct from a memorycard, go the the settings of teh printer and look for the automatic paper selection setting to switch it off.
Posted on Jan 15, 2009
  • easyq
    easyq Jan 16, 2009
    You're welcome, please don't forget to vote.
I have a HP Photosmart D7160 and it won't print 4 X 6. It has black marks on the wrong side when it comes out, but not picture
Try flipping the paper. Probably you need to resize the image for this size, sounds like it is compressed and squnched together into those black marks. See if you can use a preview function.
Jul 31, 2016 | HP Photosmart D7160 InkJet Printer
Printer keeps saying that we are out of paper even though photo paper is in and glossy side is down. Can't figure out why it isn't sensing that the paper is there.
Go into printers and faxes, right click on your HP PHotosmart printer, click on properties, in the general tab click on printer preferences, on the advanced tab make sure the paper type is Automatic so the printer will acknowledge any type paper put into the tray.
This may allow the printer to see your photopaper. Also try to remove the paper completely and put it back in the tray, make sure the paper is pushed all the way to the front of the tray.
Let me know if this answer is helpful. Let me know if you have any other specific questions, if so, add as much detail to the problem as possible.
Thank You,
Brian
Feb 26, 2011 | HP Photosmart D7160 InkJet Printer
HP d7160 won't print black, New cartridge. Goes through the motions - but nothing hits the paper. Colors print fine. What gives?
1. Turn printer off and disconnect the USB cable from the PC to printer
2. Uninstall the printer driver and software-->here's how.
Navigate here for printer driver and software .(Select your Operating System and click next)
Install the printer driver and software -->here's how
Feb 23, 2011 | HP Photosmart D7160 InkJet Printer
How do i clean the rollers on a hp photosmart d7160
  1. Remove the power cord from the electrical outlet. Open the printer cover and expose the printer rollers.
  2. Remove the paper from the "in" tray and any paper you may have in the "out" tray.
  3. Hold the wet cloth against the first roller with one hand and use the other hand to manually turn the roller.
  4. Replace the paper in the in tray. Plug the printer in and print a test page. The rollers should take the paper from the in tray. If not, repeat the process in Step 3 to make sure you remove all of the dirt.
A HELPFULL IMAGE:---- 261257_thumb.jpg OK. thanks.
Aug 14, 2009 | HP Photosmart D7160 InkJet Printer
How do you open HP Photosmart D7360 Printer case? We had a paper jam and part of the page ripped and we can't find it. I think it may be stuck under the print head.
Hold the bottom base of the printer with one hand, grasp the top cover under the HP logo, and pull upward with the other hand.
Aug 12, 2009 | HP Photosmart D7160 InkJet Printer
Prints "muddy"--have aligned, cleaned printheads, made sure cartidges are seated and full--what now?
See in printer properties you can set for poor paper qualty like blotter paper quality,, this will use less ink flow and less likely to bleed
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
Paper Size Sensor Error on HP Photosmart 3110
Can try this link
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 01, 2009 | HP Photosmart D7160 InkJet Printer
Photosmart D7160 - No lights - Won't turn on.
Hey there u just clean cattriz with a soft damp cloth like metrial that is after reinserting the catrizs
Apr 05, 2009 | HP Photosmart D7160 InkJet Printer
Ink not printing the same image quality that is on computer
Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
