HP ProLiant DL120 G5  Server Logo
Anonymous Posted on Dec 19, 2012
Dl125 G5 no boot even to BIOS
I have an HP ProLiant DL120 G5 server that powers on, but doesn't boot up (Even to BIOS). The fans never spin down, and just continue to spin full-speed I've reseated all components, and reset BIOS(Take battery out and unplug for couple of mins). I've also removed each stick of RAM individually incase it's faulty, but no luck, still no boot Anything else i should try? Any suggestions? Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1291
Points
18
Hello! Try another disk.
  • 1 more comment
  • Anonymous Dec 31, 2012
    Thanks for the reply Kjetil,
    oops, sorry, pressed Enter too soon. Unfortuantley i was unable to get to any BIOS Screen, and still was not able to get to a BIOS or Boot screen even after unplugging all Hdds and optical drives. So trying another disk didn't help either. I ended up leaving the CMOS battery out for about 15mins, and reseating the CPU, RAM and all cables again, then it booted up.. Strange but at least it's up and still working now!
  • Roland Hall Mar 17, 2013
    If draining the CMOS battery worked, then it might go bad again. Make sure you have all the BIOS settings. Unless you have a short across the bus the power supply could be intermittently failing. An ohm meter would tell you if the power supply is putting out what it needs. The CMOS chips doesn't have anything to do with powering the fans.
4 Related Answers
Anonymous
  • 44 Answers
  • Posted on Nov 28, 2011
SOURCE: My Hp proliant Ml110 g5 server powers on, but
1) disconnect hdd and check
2) update BIOS from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3984626&taskId=135&prodTypeId=15351&prodSeriesId=3984625&lang=en&cc=us
not solved then change powersupply.
That's it
Bob F
  • 48 Answers
  • Posted on Mar 20, 2009
SOURCE: HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mikenet2620
Miguel Espinoza
  • 106 Answers
  • Posted on Aug 17, 2010
SOURCE: I can't boot my hp
Enter the bios During POST, press F10.
access the boot menu from the list of devices in the list choose your cd save and restart
Anonymous
  • 2878 Answers
  • Posted on Dec 12, 2012
SOURCE: Open Proliant ML150 G5 tower without the key
Order from HP - Front bezel key 459183-001
Hp proliant dl 180 g5 cooling fan issues fan given noise
I would power the server off. Blow it out with a can of air. Power it back up.. If it is still making a noise, you need to replace the fan.
3helpful
2answers
How to reset bios password on hp ProLiant 360 g5
power off server,switch on SW6 of the Maintainance switch.Boot server.Switch of the server and put back the SW6 to OFF Position.Then switch on the server.Your NVRAM(CMOS) is cleared
9helpful
My hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay . this problem used to happens from time to time...
my hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay .
1helpful
I can't boot my hp proliant DL120 G5 server from a CD
2helpful
Dl360 g5 not booting, fans running full speed
Confirm whether the RAM are plugged in properly. It could be the reason for the boot screen not moving beyond the BIOS boot up
I have HP ProLiant DL360 G5 Server i found
For Server-HP Proliant , Boot using SmartStart Cd(if you don't have download iso image from HP support site--Free & burn it to media)
Now boot using this Smartstart cd and choose Maintain Server...Use Diagostic options..to check hardware.....Also check Drives status....if amber light
Replace hardware or it is Contact HP for any hardware issue
1helpful
3answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
