Question about Samsung RS2556 Side by Side Refrigerator
Samsung RS2556SH Freezer left open. compressor does not come on.
My elderly Mom left the freezer door open a bit yet not enough to cause it to beep I'm guessing. It was unplugged and replugged in 2 hrs later to allow it to cool and reset itself, yet now I cannot get the compressor to start back up.. HELP!
  • 2 more comments
  • Charles Pasha Jun 16, 2007
    Tresilla, first, thanks for your help and advice. I too thought of this and have left it for several hrs.. maybe 10-12.. I hope that does the trick in this warm weather because I cannot let the food get too warm on the Fridge side.. Its staying rather cool I must admit.
    I am going to try to plug her in, but if its still not working does anyone have the schematic or directions to remove the freezer side panel? I'm an auto technician, so I have some sort of clue as to what I'm doing (I hope ; >~
  • Charles Pasha Jun 17, 2007
    I removed the cover found a little football sized chamber on top of the coils to be frozen. I defrosted and dried everything well with a heat gun and air compressor. Fan in cover is free spinning.. Replaced cover and tried again.. got to 37 degrees on fridge side and 57 on freezer... Fan is running at the compressor and I have blown all coils in back free of debris.. Next?>?
  • Charles Pasha Jun 30, 2014
    Yup,got that as well,http://www.appliancepartspros.com/parts-...
    Found it athttp://www.appliancepartspros.com/parts-...
    President:
  • 1,462 Answers
If door was left open for some time, there may be excess ice build-up on the evaporator which may take more than 2 hours to clear. two methods to cure switch off and leave for 24 hours with doors open. or remove back panel in freezer and carefully melt ice off with a hairdryer
Posted on Jun 16, 2007
  • douglas smith Jun 16, 2007
    its the freezer back panel you nneed to remove!
    also, take the cover off the compressor electrics and check if the compressor is powered up
  • douglas smith Jun 18, 2007
    is compressor running? should be if compressor fan is running. if compressor is running or not running and warm to touch then points to a system or compressor fault. check if compressor is powered up by removing cover over compressor electrics. don't think fault is related to your mum leaving door open
SOURCE:
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
MY SAMSUNG RF217ABBP REFRIGERATOR FREEZER WON'T STAY ON
same as the last post...If the refrigerator wont stay on the start relay may be defective. This may have been caused by the leaking door that overloaded the system. The relay is a small box mounted to the side of the compressor and provides power to the compressor start winding for a split second at start-up to help get the compressor get started. If its defective the compressor may run off and on (a lot) or not at all and the refrigerator will not get cold enough. Fairly easy to do and reasonable
May 17, 2014 | Samsung RF217ABBP Bottom Freezer French...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Freezer door left open will it work again?
yes it must be shut off and completely defrosted.with doors left open it usually takes about 2 days. what happened if you look at the back wall in the freezer from the inside you will see a bunch of ice and there is more behind that panel you are looking at. it froze up the coils so that no air will get through them. good luck rich
Sep 18, 2012 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator and freezer were working properly before an extended vacation. Cleaned both refrigerator and freezer, unplugged, and left doors open. Upon return plugged in and have waited 72 hours. ...
Let's think this through a bit....
You say it is cooling but it seems too quiet.... is the compressor runing but the condenser fan is not??? that would make it cool but not cold and also make it more quiet...
If both compressor and condenser fan are running... is the evaporator fan... the one inside the freezer running? That also could cause the same problems...
Is the compressor running all of the time??? or is it cycling? if it is cycling then it could be a t-stat or sensor problem....if it is not starting properly it may be a capacitor/relay problem...
These are alll things that you can easily check yourself....
If they all checkout... then the unit may have a small refrigerant leak and just will not cool enough now to catchup from a earm condition....
To check that out you would need a tech. to attach gauges to the system and check the charge...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Sep 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Compressor is not running, poping sound when electricity supplied
The popping sound could be a direct short circuit, in which case you need to try to see where exactly the sound is coming from. You should then be able to correct it. Second thing is that it is possibly a bad starter relay and can easily be replaced. ratemeplease
Mar 12, 2009 | Samsung 25.5 Cu. Ft. Side-by-Side...
Fisher and paykel E240B refrigerator freezer has just started beeping 11 times when i open the door and is not freezing in the freezer cold enough
I called F&P customer care when my fridge did this, and apparently 11 beeps means the compressor has failed. I hope you got someone to fix your fridge! I decided to post a solution as I couldn't find one online anywhere!
Aug 18, 2008 | Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
1,339 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
