Question about Philips HTS3450 System
Sound from 3 channels only
I inherited an HTS 3450 when we bought our house, however it only produces sound in 3 channels:Right Front, Right Rear, and Left Rear.
I have tried the speaker connectors from the silent speakers in the active speaker slots and all 5 speakers work when tested, but not sure the subwoofer has sound Thinking the subwoofer was faulty, I patiently waited and found a replacement subwoofer (and all other speakers) on Ebay for a decent price. Well the replacement subwoofer functions exactly the same with sound only from the same 3 channels. Now I think the problem is in the DVD/Receiver unit; it must only be sending those 3 channels to the subwoofer. I cannot beleive that I have 2 subwoofers with the exact same combination of failures. Any comments will be appreciated.
Thanks.
Oklahoma City
  • 2 more comments
  • sdown Jan 15, 2009
    Thanks easyq. I have run the individual speaker test signal procedure with the results I mentioned...no sound from Center or Left Front unless I plug these speakers into the other/working speaker connections, and this is exactly the same with both subwoofers. I have also worked carefully to have the system setup so that it is in 5.2 surround sound. It has an option to go into stereo sound only, which produces sound only in the Left Front.
    I will next try your suggestion about downloading firmware update, but I don't have a clue how I would transfer an update from the website to the Phillips system, I know there is a USB port so I guess that is the procedure. Thanks again.
  • sdown Jan 28, 2009
    OK, I located another receiver/DVD unit which is like new. I tested it tonight and have the EXACT SAME conditions...sound only coming from the same 3 speaker plugs/sockets. It doesn't matter which speaker I plug into the sockets, sound comes only from right front, and both rears. I have tried 4 combinations as I now have 2 complete HTS3450/37 systems, and both subwoofers and both DVD/receivers function the same. I think I must be missing something but have reviewed the manual many times and repeated my setups many times. I have been performing the test signal procedure and nothing helps. Any ideas anyone?
    The DVD/receiver connects to the powered sub with a VGA cable. The sub has connectors for the 5 speakers. I have tried 2 different VGA cables with both units connected to both subs. All speakers work when plugged into one of the 3 sockets that are working. I read that if the unit is in stereo versus 5.1 surround that the 2 fronts and the center work...I have the left front and 2 rears working only. There is an option to reset factory defaults on the setup menu. I will try this next. I agree that it is unlikely that 2 separate units have the exact same defect. I am baffled. Plan to try calling Philips today (not very hopeful here). I have scoured the Philips site for firmware updates for HTS3450/37 without results...anyway the updates seem to be for DVD compatibility and region codes only. This weekend I plan to start from scratch and retest everything, and I will post any results. Next step is to list all of it on Ebay and be rid of the entire lot. Thanks for reading.
  • sdown Jan 29, 2009
    PROBLEM SOLVED!! OK call me ignorant, it WAS my error. When I bought this house the Philips system was instaled in a bedroom with the DVD/receiver located in a closet. The wiring was routed up into the attic and then down in the wall of the bedroom. I relocated the system and could not use the wiring hookup so I took another cable from an old computer monitor. I have been trying to use the system with a lightweight VGA cable with blue fittings, in fact I tried 3 different ones with no luck. I figured if the cable plug matched the sockets it was the proper cable. After eliminating all other possibilities, it had to be this cable. I looked at the original cable in the closet and noted that although the cable plugs were identical with the same number of pins, the cable itself was quite larger in diameter, but the end fittings were black and squared-off as opposed to blue and "rounded-off". When I reattached the sub to the receiver with this cable,,,,it works as designed, all speakers producing sound! Not sure what the differences in the cables are...there are identifying writings on the black one, but I am just leaving it be. I now have 2 complete WORKING Philips HTS3450 systems. I still may go to Ebay this weekend and try to recover the money spent when I duplicated the speakers then the DVD/receiver.
    I want to thank 'easyq' for his help. Sorry to waste anyone's time with this long-winded story, but I thought my experience might help someone else. Have a good day.
    Steve in OKC.
    Scholar:
  • 144 Answers
Hi, first of all did you verify with the manual if it is possible to run a testsignal through all 5 channels?
One of the most common problems in this case is the basic settings of the device. If you don't have the manual, mostly you can download them from manufacturers website. Chances are that for some reason the setting is set 3.0 stereo (also known as 3channel sound) which is always the 2 fronts and the centre speaker.
Best thing to do it is take a DVD with THX on it and run the THX setup, it will send test signal to all channels.
Posted on Jan 15, 2009
  • 2 more comments
  • easyq
    easyq Jan 15, 2009
    Otherwise, check which of the 4 models 3450 you have and download the firmwware update from philips website, this might also do the trick.
  • easyq
    easyq Jan 15, 2009
    Firmware updates most times have a how-to in the download, don't worry about that part.
    Hopefully it solves your problem, if not i think you device is defective.
  • easyq
    easyq Jan 28, 2009
    Did you use the same speakerwiring for all tests, as that seems to be the last option that could be the failure?
    It is (almost) impossible both sets have the same problem.
    How do your speakers have to be connected, from the back of the set itself or from the subwoofer?
    If there is only 1 cable from teh set to the subwoofer and from there the speakerscables, switch that cable. If it doesnot help switch speakercables (not tthe speakers itself) from a working to a nonworking to check if it's now working or simply replace all speakercable for new to be sure to rule out the cables.
  • easyq
    easyq Jan 29, 2009
    Steve, i am so glad it is solved, this one was getting on my nerves as i could not get what was wrong. Just FYI, the difference in cable is the number of connected pins, in a normal VGA cable there are basically 3 pins connected for RGB (red, Green, Blue) which clarifies sound from only 3 speakers. The correct cables has all pins wired that's why it is so much thicker. Even not al pins are used, they are all in the plug to avoid it from being to loose into it's socket and because it is a standard plug.
    Hope you can get some cash back on ebay, at leats you can sell it as a correct working model ;-)
    Edgar from The Netherlands
2 Suggested Answers
heavyice
  • 374 Answers
SOURCE: Sound from 3 channels only
Sometimes what happens is that people r just confused with all wirings.Considering that you have connected the speakers correctly...Now according to u the center speaker is not working
  1. If u have a jack attached at the end of the speakers then try connecting the center speaker jack into the Right front/Right Rear/Left Rear socket at the back of the reciever.Just to make sure that your speakers r fine.
  2. Secondly play an audio cd first,sumtimes a video DVD not being 5.1 channel one confuses a lot.
  3. Assuming that you have checked the center speaker,like I asked u too,Connect it into its proper socket or better connect all the speakers.
  4. Now with the remote you check the predefined equalizer in it n keep changing that [pop,rock,jazz etc] or you might even want it to change it to 5.1 from a 3channel or 2channel Stereo.Everytime you change it listen to every speaker.
  5. Also check that you have increased all the speakers volume one-by-one.
  6. Disconnect any headphones attached.
  7. Switch on the selected source or select another source.
For further details u can check the manual.
The VGA cable of the monitor will work fine.
Posted on Jun 03, 2009
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Why won't my TV sound go through the Hts 3450?
Wide open one here. Is your tv coming in direct from the wall or do you have a cable/digital box that you need to get the signal from? If you have a box then make sure you are plugged into the audio out on the box and on the HTS you are on the audio in. There will be a left and right. If you have the sound to your tv then you can plug into the audio out on your tv and again plug into your audio in on your box. If your tv has an option for external speakers then you need to make that adjustment on the audio menu on your tv. Also make sure that the proper channel is selected on your HTS and that your audio output matches your selection. Hope this helps but I will keep an eye out for further posts.
Nov 12, 2012 | Philips HTS3450 System
Hi i, recently bought new philips hts 3510 but it aint having enough sound in both right and left rear speakers when comparing to front speakers which means only very low sound as well as effect in rear...
I can't find the manual. Hopefully you have it and can follow the setup procedures. These things aren't plug and play and we can't assume you have done so.
Sep 10, 2011 | Philips Audio Players & Recorders
When i go to surround mode right front channel drops out
check for connection, might be the front right speaker was connected to right rear soround out, check recording if dolby pro logic or DTS system
Aug 31, 2009 | Denon AVR-3600
Jun 03, 2009 | Philips HTS3450 System
Rear speakers won't play sound.
check on the front of the unit for a speaker selector- make sure A & B is selected
Feb 04, 2009 | Kenwood VR-307 Receiver
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
HTS 3450 subwoffer off
I have a similar problem. I inspected the power board and found IC901 burned completely. I cannot find out the part number and have tried to get a reply from phillips but have not heard back from them. Anyone have a schematic or can give me the part # of IC901?
Sep 06, 2008 | Philips HTS3450 System
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Philips HTS3450 System Logo
300 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
