Question about Kenmore 64952 Electric Dryer
Dryer will not run
I put a load of towels in dryer and put it on, in the middle of cycle it shut off. It did not trip the breaker. I tried to look at the motor, but I can't figure out how to take the back panel off???? I checked to see if there was fire to the switch and there was. You can hear it trying to come on when I press the start button, but all I hear is a clicking sound.
  • 87 Answers
Replace thermal fuze.
Posted on Jun 17, 2007
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
It caused the problem. Appliance repair person
May 13, 2017 | Whirlpool Dryers
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
The dryer runs fine with no load but as soon as i add clothes aft
Sounds like the motor may be on its way out. a motor, over time can form a short or require more amps to do its job but can cause the breaker to trip. Also over time, dust and lint can build up over time, inside the dryer and cause it to over-heat.
Apr 26, 2009 | Whirlpool Inglis IP8200 Dryer
My dryer takes much longer to dry loads now
Hi!
You need to check the following things to sort out the issue you are facing with--
Improper sorting •Separate heavy items from lightweight items (generally, to dry a well-sorted washer load is a well-sorted dryer load).
Large loads of heavy fabrics •Large, heavy fabrics contain more moisture and take (like beach towels) longer to dry. Separate large, heavy fabrics into smaller loads to speed drying time.
Controls improperly set •Match control settings to the load you are drying.
Lint filter is full •Clean lint filter before every load.
Improper or obstructed ducting •Check installation instructions for proper ducting/venting.
•Make sure ducting is clean, free of kinks and unobstructed.
•Check to see if outside wall damper operates easily.
•Check the Installation Instructions to make sure the dryer venting is correct.
Blown fuses or tripped •Replace fuses or reset circuit breakers. Since most dryers circuit breaker use 2 fuses/breakers, make sure both are operating.
Overloading/combining loads •Do not put more than one washer load in the dryer at a time.
Underloading •If you are drying only one or two items, add a few items to ensure proper tumbling.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Thanks
Rylee
Apr 03, 2009 | GE DVLR223 Dryers
The dryer acts as if no electricity is going to it. It shut off
Is this an electric or gas dryer? If electric, it would be wired seperately from the washer (220V vs 110V) and if so, maybe you tripped a circuit breaker or blew a fuse - that would be the first thing I would check. If you find nothing wrong there, I believe most dryers have an internal overload circuit and if you are not handy, an appliance repairman, or an electrician, I would suggest calling an expert.
If you did trip a circuit breaker and reset it, and it trips again.....better call for service.
Dec 10, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Help
Check your circuit breaker. Even if it doesn't look tripped reset it anyhow. Try that first.
Nov 30, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 64952 Electric Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
