Question about Dewalt D28494N 7" and larger Electric angle grinders
Sparking bruch the grinder is having ring spark and giving out smoke
Most likely the carbon brush is worn out and need to be replaced.
Posted on Jan 15, 2009
What could blue tailpipe smoke be from?
Your issue could be a few things. Simplest first would be the PVC valve. Other issue would be valve seals, valve guides or piton rings. The blue smoke is from your vehicle burning oil
May 19, 2014 | 1988 Toyota Supra
Engine oil coming out from the sparkplug how to repair
if you have engine oil inside any cylinder you have major problems. possible broken rings, severely worn rings. need engine rebuild or replacement
Feb 09, 2018 | Hyundai Motor 1998 Accent
Why to much sparks in the brushes
Low power and lots of sparks from the brushes is usually indicative of a damaged commutator (the ring where the brushes contact the armature) or burnt or broken windings on the armature. The only fix for either of these problems is to replace the armature.
Apr 28, 2012 | Clarke Power Products 7 in 9 in Angle...
My plymouth voyager just started smoking
If its bluish smoke coming out of the exhaust, then engine oil is leaking past the piston's oil rings. You'll need an engine rebuild, or give its last rites before sending to the salvage yard. If it's white, it should clear up as the engine warms up. White smoke is caused by lack of heat temperature in the combustion chamber. If the engine is warm, and its still smoking (black smoke), then too much fuel is entering one (or more) of the cylinders, which is often caused by a faulty fuel injector. To diagnose which injector is faulty, remove and inspect each spark plug. Any Haynes or Chilton manual has a spark plug section showing what a normal spark plug should look like, versus one caused by faulty injectors.
Sep 24, 2010 | 1994 Plymouth Voyager
My leaf blower statred smoking a little and then
dont sound good but you could try this, put some motor oil in the cyclinder which gives it false compression couple of table spoons ,remove the spark plug put 2 spoonsfull in the cyclinder put the sparkplug back in it should start sometimes it will free the rings or if it just runs a little then quits the rings or ring could be stuck
Nov 03, 2009 | Troy Garden
Having trouble with my honda 2001 cbr smoke coming out of exhaust pipe
There are several possible causes; fuel mixture is too rich, air filter is clogged, or worn piston rings and/or valve guide seals. The latter, however, will most likely produce blue smoke - under acceleration means worn rings, blue smoke under deceleration means bad valve guide seals. Also make sure that the crankcase vent is not obstructed as this will tend to force oil up, past the rings and into the combustion process.
Generally, an examination of the spark plugs will give you a good clue as to what the offender is. Black, sooty spark plugs indicates too much fuel (clogged air filter or mixture too rich). Oily spark plugs means worn engine parts, as mentioned above.
Oct 27, 2009 | 2001 Honda CBR 929 RR Fireblade
Dewalt D28494N 7" and larger Electric angle grinders Logo
222 people viewed this question
Top Dewalt Saws Experts
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
