Question about Uniden Radio Communications
I need to buy a two way radio for car service with 200watts
The company lower east side car service radio big competition among radios in oder to get a customer
  • alex2392 Jan 15, 2009
    What two way radio i should buy
    Sergeant:
  • 367 Answers
Hi, I need car audio code for my ford figo 2012, model 14790965, Sr.# 419591170965, this car audio is made by Sanyo Automedia
check your pawn shops in the area also you may need the u shaped pins to remove the radio in the dash I think amazon ebay might have them there are 2 holes on dash mounted radios top and bottom each side look for them put the u pins in each hole and then pull the pins at the same time the radio will come out hope this helps you good luck
Apr 18, 2016 | Ford Cars & Trucks
How to change the region on the tv
your going to go to a place sale electronic/tv. your going have buy a converter, the converter changes from pal to usa configuration, take the old cable with you and the new cable you need to convert.
radio shack, big box stores, tv repair places, where the deal with tv and installation service, walmart mite have it, electronic wholesaler,
you r also going to buy power adapter for cycle change or plug in, you just plug it into power cord and than plug into wall. the converter will transfer the 50 cycle to 60 cycles that the united states uses.
you find online, walmart, radio shack, where they may sale tv or call tv repair shop ask for help.
Oct 09, 2015 | Computers & Internet
Radio either does not come on or if does cuts in and out.
Check your antenna wire. It works as ground and reception. Pull out radio and should be on lower right side ( big black wire ) also check connector to the right of passengers right foot behind panel
Nov 20, 2013 | 2001 Chevrolet Monte Carlo
I need help takingmy dash apart to install a aftermarket cd player
Most newer vehicles don't requie a dashboard hatchet job to get the radio out.
Once the trim panel is removed from the radio face you'll see a slot at the top
sides (both sides) of the radio chassis. These slots are for the insertion of thin
metal strips (look like tiny "slim-jims" used for opening doors) that have dedicated
unlocking ends. Pushing both of these strips in at the same time will unlock
the radio from the car and is removed by removing the radio AND the strips at
the same time. I don't know where you can buy these unlockers separately if
they didn't come with your replacement radio. Talk to someone at Crutchfield.com
to see if they'll send you a pair...They're into automotive audio big time.
If this doesn't help then repost your request.......Ray
Jan 20, 2011 | 1998 Oldsmobile Bravada
I have a general lee and I am running a 2 by 8 box. What should I turn my radio down too to run this box I was told 3 watts wgat do I turn to accomplish this I doesn't seem to have much modulation either
The radio needs to be tuned for the box. 3 watts sounds too high for a 2x8.
I would say it would be more like 1-1/5 to 2 watts. That may be why your not getting that much swing.
You should set the radio so the box dead keys around 300 to 400 watts.
Aug 24, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I changed the Navigation disc to west side and can't get it to accept the east side navigation Disc? Is it possible? How?
eject the disc and reset the radio. then try to insert the east coast disc again. should work again after reset
Feb 06, 2010 | Pioneer AVIC-N2 DVD/CD/navigation receiver...
3300hp stoped transmitting iwould like to know what around about cost for repair . and best place to my radio to . i live in oklahoma.
in temple, tx take exit 299 east to hwy 95 and fm 93 service road.
lowest prices... depending on prob with radio around $25 -$45 on most problems like that...
Nov 06, 2009 | Connex 3300 240-Channels Base CB Radio
Hi ,i was wondering if you could give me the code for my clarion radio,its out of a 1996 discovery,on the paper bit it reads,AMR219LNF,product no PU 9845A,under that its got 286-7639-07,then stamped on the...
the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with C7000000 + + + +  on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM
Oct 21, 2009 | Car Audio & Video
Terracan radio
Is quite easy. You have to pull out the center dash console, buy yanking it out. You can pull out from the ashray then to loosen the lower part, then carfully pull out from sides and top. Take care with any wire harness attached (switches). Once center console is out, you will find two or four screws on both sides of the radio. Unscrewing this ones will let you pull out the radio unit fully and access the wiring harness and antena lead.
Mar 15, 2009 | OEM Systems Car Audio & Video
Radio Communications Logo
50 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
