Question about Radio Communications
I need a two way radio for car service in new york with 200 watts
  • 790 Answers
Hi
wow this is a powerful Rf amplifier... ok just go to this site where you get what you want! http://www.twowayradioonline.com/
Thanks!
Posted on Jan 15, 2009
2 Suggested Answers
eradiostore
  • 1640 Answers
SOURCE: mobile two way radio for car service in new york
Generally 100-110 watts is the most you will find in a mobile FM 2-way radio. However, if your FCC license permits more wattage, you can use an amplifier to boost your power. More wattage does not necessarily equate into more range. Height, placement and tuning of your antenna determines your range. Check with your local FM radio dealer to determine which model will work best in your area.
I have a cm200 base station and need to sync it with my cp 200 radios
hi Raymond, we're a Motorola /Vertex Dealer and have the software and cables to program everything to match. as long as they are all on the same frequency range (meaning the new Portables are not VHF and the base is UHF, if both are the same, we can take care of programming for you, $35 each unit programmed. shoot an email over to us metrocom2 @ yahoo (dot) com - jenny
www.metrocomdc.com
Mar 20, 2014 | Motorola Radio Communications
How to connect sb-200 to ic-7600
you really need a amp keyer interface, these new radios are voltage sensitive, I use ameritrons http://www.ameritron.com/Product.php?productid=ARB-704
Nov 19, 2013 | Icom Ic-A110 - VHF Air Band Transceiver...
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
How to set low power in midland LXT300
  • The Hi and Low power are built into the radio and is dependent on the frequency/ channel you are on. Hi power is 1 Watt and Low power is .5 Watt. The radio is GMRS and FRS. The FRS are low power and the GMRS are Hi power.
  • Channels 1-14 are FRS frequencies and Low power.
  • Channels 15-22 are High power and are GMRS frequencies.
  • FRS = Family Radio Service.
  • GMRS = General Mobile Radio Service.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 28, 2011 | Midland LXT303-A 2-Way Radio
Why wont my motorola cp 200 work with other radios
1) It is not programmed to match the other radios.
2) It is in need of repair.
3) It might simply need a new battery pack.
See your local Motorola dealer for more assistance.
Best regards.
Jan 18, 2011 | Motorola Talkabout SX900R Two Way Radio
I need to know the watt of the t5509
The TalkAbout radios are 1/2 watt radios, with exception of the older larger TalkAbout Distance and Distance DPS, which were 1-2 watts.
Best regards.
Apr 12, 2010 | Motorola Talkabout T5500 (7 Channels)...
Peak and tune a mini magnum 30 10 meter radio
You need schematics and a good peak reading watt meter. You can do damage if you don't have eqipment/knowledge.
Mar 16, 2009 | Motorola OEM Compatible 6060937H02 Two-Way...
Mobile two way radio for car service in new york
Jan 15, 2009 | Radio Communications
Looking for a charger raeleen
Raeleen
Do you still want the Bellsouth Model FW13Z Two-Way radios?
I tried to e-mail you at darnette_hill@bshsi.org and never heard back.
Please e-mail me at alan.s.bitzer@power.alstom.com if you still want them and I can get an address to send them to.
Aug 03, 2008 | BellSouth FW13ZHS (14 Channels) 2-Way...
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
