Programming in c
I need source codes in c that is converting hexadecimal numbers to binary, octal and decimal
  • 258 Answers
To convert numbers you can use the printf() function
printf("%d", x'FF') hex to decimal
printf("%o", x'FF') hex to octal
If you want to save the value in another variables use sprintf
e.g
a = x'FF';
b = sprintf("%d",a)
Posted on Jan 16, 2009
What is the meaning of octal
The octal numeral system, or oct for short, is the base-8 number system, and uses the digits 0 to 7. Octal numerals can be made from binary numerals by grouping consecutive binary digits into groups of three (starting from the right). For example, the binary representation for decimal 74 is 1001010, which can be grouped into (00)1 001 010 - so the octal representation is 112.
In the decimal system each decimal place is a power of ten. For example:
bcd885da3009955a0aaca3e7bb004380.png In the octal system each place is a power of eight. For example:
4219c7fffd93294e3d48bba6f898bd79.png By performing the calculation above in the familiar decimal system we see why 112 in octal is equal to 64+8+2 = 74 in decimal.
Hope this helps
Jul 15, 2014 | Necchi Sewing Machines
How to convert a dinary number to a binary number using a casio fx-82MS calculator
Dinary? Never heard that one before. What is a dinary number? Anyway your calculator cannot perform the operations. The Casios can work in Binary (base 2), Octal (base 8), Decimal (base 10) and Hexadecimal (base 16). Some Sharps can do calculations in base 5 (pental).
Feb 19, 2013 | Office Equipment & Supplies
Converting from BASE-N to Decimal
If you want to convert from another base to decimal, press MODE 4 to enter the BASE-N mode, select the initial base (binary, octal, or hexadecimal), enter the number, then switch to decimal to see the value in decimal.
If you want to exit the BASE-N mode, press MODE 1 to switch to the computational model or MODE 2 for complex mode.
Oct 04, 2011 | Casio FX-115ES Scientific Calculator
How to get from dec. to binary
If you're already in decimal mode, press SHIFT BIN to switch to binary mode.
To convert a number from decimal to binary, press MODE 4 to switch to BASE-N mode. You'll find yourself in decimal mode. Enter the number to convert, press =, then press SHIFT [BIN] (the log key) and see the number in binary. To convert another number, press SHIFT [DEC] to return to decimal, enter the number, press =, then press SHIFT [BIN]. An analogous process works for hexadecimal and octal as well.
To return to "normal" use, press MODE 1 for COMP mode or MODE 2 for complex mode.
Mar 12, 2011 | Casio FX-115ES Scientific Calculator
How do you convert decimal numbers into binary?
Press MODE 4 to enter the BASE-N mode. Type in the decimal number, then press BIN to convert to binary. Press DEC to switch back to decimal for the next conversion.
You're limited to numbers in the range [-32768...32767] in binary. You can extend the range if you convert to octal or hexadecimal and then mentally convert each digit to three or four bits.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Binary conversion
In the FX-300Ms manual, the same for the FX-82MS, there is no way to use base-n (binary, octal, hexadecimal) calculations.
Sorry.
Feb 22, 2009 | Casio FX-300MS Calculator
C++ program for the conversion of decimal numbers to hexadecimal
all your solution is at
http://www.c.happycodings.com/Beginners_Lab_Assignments/code18.html
Dec 07, 2008 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
