Question about Electrolux EW1000i Front Load Washer
Door seal how to replace door seal because it is covered in mould
    President:
  • 842 Answers
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until ot is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 09, 2009
5 Suggested Answers
  • 1294 Answers
SOURCE: Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Posted on Jan 02, 2008
SOURCE: Maytag front loader washing machine. Mould
I had the same problem with my Neptune washer until I ran a cycle with straight vinegar and water.  This helped get rid of the mold.  I have to run a "vinegar" cycle about every 10 cycles.  I would try cleaning the seal with vinegar first and let it air dry.  Neptune washers need to air dry after every cycle.
Posted on Dec 14, 2009
  • 56 Answers
SOURCE: mould build up on the grey door seal. tried bleech
the mold is caused from too much soap. a front load uses such a small amount of water only 2 tablespoons of soap is needed. replace the boot and cut down on the soap
Posted on Feb 07, 2010
marka19
  • 1430 Answers
SOURCE: black mould has formed on
Try cleaning with a 50-50 bleach water mix. You will need to reach in and pull the seal almost inside out to thouroghly clean it. If there is still black mold after cleaning it will come back in short order and i would recomend replacing. If you do replace try wiping out the seal( way down in it) after every use and leave the door adjar. Here is a link that should help with Replacing a door seal
Posted on Sep 22, 2010
Removal of rear door exterior lower moulding
the FSM covers this.,
a $4 look
https://suzukipitstopplus.com/Products/10218-2000-vitara-grand-vitara-service-manual.aspx
ill open mine now.
i have no idea at all where hands are touching/? photos?
is this body trim or door trim.
chapter 9 covers this. in the book.
but ive no idea what exact part you are touching.
are is this the seals, or plastic part?
post a photo with finger pointing....
Dec 07, 2014 | 2000 Suzuki Grand Vitara
Mold door seal
If you want the door seal replaced any local domestic engineer will be able to do this. The mould is caused by excess detergent, constant washing at low temperatures, keeping the door closed when the machine is not in use. If you want to stop the mould reappearing once the seal has been replaced you need to carry out regular service washes (boil wash with a descaler/sanitiser). Use the correct amount of detergent for the amount of washing to be done and the hardness of the water in your area. Give the door seal a quick wipe after you use it and try and keep the door slighlty ajar when not in use.
Oct 18, 2013 | Siemens WFXD5200UC Front Load Washer
Water seals
doors or windows doors the seals go under trim that must be removed most just snap in place some use screws remove and replace weather strip . door seals they seat around the top in a grove on either side and inserts along the sides and bottom. door window seals out side remove door panel remove mirror pull up remove moulding inside just pull up strip and replace.
Jul 29, 2012 | 1996 Chevrolet Suburban
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
We have a Fridgedaire front load clothes washer and we would like to know how to get rid of the mildew on the front seal?
be carefull what chemicals you use on the door seal,get in touch the manufacturer or call the appliance guy that sold it to you
Jan 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Black mould round door seal
There are several reasons for this to happen.
the primary one is the fact that you are doing a lot of low temp washes, and this causes a build up of grease and dirt around the door seal, the mould you refer to is actually bacteria.
You must do a high temp wash at least once every 6 to 8 weeks, put powder and or detergent in as usual, but no washing, and let it do a full cycle.
This is called a maintenance wash and helps prevent what has happened to your m/c.
Thoroughly clean the door seal with a scouring pad or stainless steel wool, you will not harm the seal,
You will probably find the seal will be stained, but as long as you get all the mould etc off, it will be o/k.
Plz rate my solution.
Thanks
Dec 29, 2008 | Indesit Washing Machines
Oct 13, 2007 | Zanussi FJS1225W Front Load Washer
Electrolux EW1000i Front Load Washer Logo
865 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
