Question about Xerox WorkCentre XD103F All-In-One Laser Printer
The drum light won't go out!please tell me how do I reset it?
The drum light came on indicating the drum should be replaced but having changed the drum, the light remains on...how do I get rid of the light(drum out indicator).
Ps. I managed to get into the service mode but I don't know what 2 digit number resets the drum.After inputing 24 as advised and pressing the start key, two zeros keep flashing and that's as far as I can get
  • winston-reid Jan 27, 2009
    ...absolutely brilliant my friend!I am also an Engineer but if you don't know something...you simply just don't know !
    I thought the drum light was reset in service mode like most Sharp copiers of which the Xerox is very similar in design! Many thanks again!
  • nosmoe_king Apr 21, 2009
    I have the same problem with my XD103f. I replaced an old Xerox drum with a new Xerox drum cartridge, but the error code and light won't reset. I took the green cover off and checked all of the gears, but there appears to be no flag or tab on any of them. What exactly are you referring to when you say flag or tab? Also, we need a better description as to where it is located. It wasn't obvious to me. Thank you.
    President:
  • 2,072 Answers
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Posted on Jan 15, 2009
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
I have a Brother printer MFC-8480DN and on the lcd screen it said "replace drum" I did so and also changed the toner yet it still says replace drum any ideas? I've also turned the machine off and on.
There is an installation sheet in the box the drum unit came in that tells you how to reset the drum indicator. Here is a link to my tip posted here at Fixya that may help you as well. If it works for you then please return to this posting as give feedback.
Thank You for using Fixya.
http://www.fixya.com/support/r5014960-brother_mfc_laser_printer_facsimile
Jul 12, 2010 | Brother MFC-8860DN Printer
Why does the drum light blink on my brother hl-2140
The blinking indicates that the drum unit is near the end of it's life. It will shut down soon and you will lose the ability to print until it is changed or reset.
To reset the drum counter. Press and hold down the white button (shown as blue in the image below) for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the button.
Nov 18, 2009 | Brother HL 2140 Laser Printer
Change drum on Sharp AL1642CS?
Replace the drum per the instructions enclosed. Open the right door of the copier. Remove drum by grabbing it from the locking mechanism. Be careful not to tilt the drum out of the copier. It could have toner inside of it.
Remove drum from the packaging and carefully insert it using the lower right rail as a guide. It it isn't lined up properly, you could scratch the drum. Once the drum is locked into place. Close the right door.
Press the # * C * keys on the copier.
Press 24 and the green button
Press 07 and the green button
Press the gress button again.
This will clear the drum usage counter.
Press the CA button.
Your drum is now changed and the counter has been reset.
Sep 08, 2008 | Sharp AL-1642CS Copier
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Replace drum
1.Power off the printer.
2.Open the top cover.
3.Press and hold the gray oval button on the operator panel below the indicator lights
4.While continuing to hold down the button, power on the printer.
5.The lights on the front panel will flash twice, then release the button.
The drum counter should now be reset. End of procedure.
Nov 05, 2007 | OKI B4250 Led Printer
Xerox WorkCentre XD103F All-In-One Laser Printer Logo
160 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
