Question about Reddy Heater-40,000 BTU Kerosene w/T'stat
Seems that my R-40 is not pumping fuel
I have cleaned everything, tank, filters etc... I have been using #2 deisel and it quit after 2 months of use. had the cover off and watch it start. the igniter lights up and by the time the fan/pump comes on there is a delay in when the fuel starts coming out of the nozzle, by that time the igniter goes out and it shuts down. its seems to me that it is not getting fuel soon enough to keep it running. I can set my aircompressor at 3 psi and apply air to the nozzle thru the line off the pump and it will start. I feel its not pumping enough air to the nozzle to pick up the fuel soon enough, whats the fix?
  • 232 Answers
You must set the pressure! If the heater runs with your compressor connected, but won't when the pressure is disconnected, well.......
Setting the pressure is easy!
Posted on Feb 15, 2009
Why am I having fuel issues with a 97' f-250 7.3 powerstroke, put new sensors on everything, new fuel lift pump, glow plugs,filter, new tank filter, cleaned all the lines from tank to the fuel bowl, s
If this situation occurs after a period of time then check the tank vent correctly at the vent valve on top of the tank. If it occurs reasonably quickly then check the fuel return lines from the injectors to the tank for obstruction ,kinks ,squashed etc preventing the fuel free access to the tank. check the pressure regulator to the pump is holding sufficient pressure to maintain pressure to the pumpin the pump
May 02, 2014 | 1997 Ford F250 SuperCab
E70b excavator starts to miss under load
Hi have u tried breaking the fuel line after the primer pump 2 see if u hav a strong flow using the pump. If not u might hav blockage at bottom of fuel tank and it may require clean out?
Jan 07, 2013 | Caterpillar E70B Excavator
Stalling 22r 1983 toyota truck 22r fires up, runs great then cuts out. fuel bowl goes empty and i've replaced everything, pump, filters and cleaned tank
Check the steel fuel line under the intake manifold
had one that was almost completely clogged shut with ****
took a month of hunting but found this to be the problem
May 16, 2012 | 1983 Toyota Pickup
Fuel pump is making a noise. Also when we put any amount of gas in tank it doesn't seem to want to start
first off, it seems that you may have two issues at once. 1) the noise may be from water in the tank from condensation (winter time and not filling up all the way) run some gas drier with a full tank to see if that helps. or there may be dirt of some kind in your tank clogging up the pick-up line/ sock/ filter. in that case, change the fuel filter(s) and or wait til the dirt gets filtered out of the tank.
Also, you may want to have a pressure test done to see if the fuel pump is going bad, if the noise is worse when it is hot outdoors and there is not much fuel in the tank and there is a "buzzing" sound from the pump, then the pump is likely going bad.
2) it sounds like you may have a loose connection to the fuel level sender (usually at the unit on the tank itself) I'm not familiar with this model myself as far as getting at the wiring for the sender, but it should be available in your Haynes/ Chilton, etc. manual.
Good Luck!!
Jan 04, 2012 | 2003 Cadillac CTS
I need to change the fuel filter on my 06 Pontiac G6 GT. My problem is all the autopart stores that i have been to say they don't stock them because it's too new of a car. Where can I purchase one? Also...
there is no fuel filter on the car. the fuel is filtered by the fuel pump in tank. most newer vehicles are this way. the dealers say the filter never has to be changed. but if you want, you can buy a fuel fiter and cut the fuel line, and use 2 hoses to connect it. if not i would say to use a good gas cleaner or injector fluid at least 1 or2 times a month. to keep system clean. the filter in the tank will run about 75.00 or more to drop the tank, at dealership or depending on what garage does this. good-luck!! if it lacks power, check egr valve and or clean maf sensor.
Sep 20, 2010 | 2006 Pontiac G6
Drain deisel gas from fuel pump from 2007 nissan maxim
No easy way. Tank needs to be dropped, fuel disposed of properly, tank cleaned. Also recommend doing a fuel injection system cleaning. Try to find somebody who has a motorvac injector cleaner. That cleans everything the best
May 06, 2010 | 2007 Nissan Maxima 3.5 Sl Sedan
Changed fuel pump on 99 gmc sierra and has gone out again in less than 2 months, any suggestions what could be causing it?
Did you change the fuel filter? A partially clogged fuel filter will burn up a brand new pump. Otherwise I would suspect you just got a brand new bad fuel pump. Has happened to me twice, so it is possible. Some parts I pay more for to get the OEM brand. Fuel pumps, water pumps, heater core, etc. Any hard to replace part, I buy from the dealer or from a parts store that sells the OEM brand.
Aug 03, 2009 | 1999 GMC Sierra
Put petrol into deisel tank
take of the fuel sender hose of tank and be prepared to catch any spills wen finshed fill with deisel
Oct 21, 2008 | 2003 Ford Focus
Reddy Heater-40,000 BTU Kerosene w/T'stat Logo
67 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
