Validating identity I have a laptop connected to a wireless belkin router and under status it says validating identity. Why is this happening? oh please can somebody help me...we are sitting in romania and have a hell problem with our router dlink dir 615..i am able to install it and it is working for a time..whenever i switch of the laptop or i close him my router is loosing the connection even i set up everything in setups for beeing on always...the second prob i have is validating indentity....i tried all the comments up to now but now succes..i am connected but for how long???thanks in advance....
  • vonswarengin May 25, 2009
    the wireless manager says "validating identity." Shouldn't it say, "Secured connection" instead?
SOURCE: validating identity
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Graham
UK
Posted on Jun 21, 2008
jkhtkd
  • 4 Answers
SOURCE: DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
Posted on Jan 29, 2009
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
  • 10 Answers
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Posted on Sep 13, 2009
Testimonial: "tanks v. much for answer, i'll try it right away"
govinda123
  • 2263 Answers
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Posted on Jan 12, 2010
Validate identity
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 31, 2011 | Belkin Basic Wireless Router
I have a cisco by linksys and i have validating indentity went a enable on seting and my labtop came up but i still have validating identity when i start up lab top status connection will this go away if...
you will have an option called wifi protected setup(wps)...You need to disable this particular feature...
This feature when enabled gives the error message like "validating identity"...
or by the other way instead of disabling the wps, you can add the network manually by entering the network information like ssid, password and security type...
This will also help....
This is a 100% proven solution for validating identity....
Because I directly work for Belkin....
Dec 11, 2010 | Belkin (F5D5231-4) Router
My wireless connection is showing the status of Validating Identity after installing my new netgear Router. What should I do
Please follow the steps as mentioned in the below link to resolve the issue:
Validating Identity
If you need any further assistance then please let me know.
Regards
Anand
May 20, 2010 | NetGear WGR614 Wireless Router
The router status is saying 'validating identity'. One of the computers in the house is able to connect, but the other one won't.
The computer that will not connect does not have security settings that match the router settings. You need to consult your router manual, determine what those settings are on the rounter, then go into your control panel and under "wireless" set them to match.
Jul 13, 2009 | D-Link Computers & Internet
Laptop says validating identity
Right click on wireless network connection and go to properties. From the Wireless Networks tab, choose your wireless network and then click Properties.
Click the Authentication tab. On the Authentication tab, Uncheck"Enable IEEE 802.1x authentication" for this network check box. and click oK.
Now reconnect to the wireless network and you will be able to connect to it.
IF you still face issue then please enable WPA encryption on the wireless router and that should work fine with both the laptops.
Rate it, if it helps.
Jun 27, 2009 | Belkin Computers & Internet
Cant find certificate for wireless
Jun 14, 2009 | Belkin (F5D5231-4) Router
Help
hello!
check if the wireless settings of your router match the wireless settings of your laptop. by the way, do you have a wireless adapter installed on your laptop? if yes, is it tun on / enabled or installed properly?
Apr 30, 2008 | Belkin (F5D7230-4) Router (587009)
Validating identity
Graham
UK
Jan 20, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
1,309 people viewed this question
David Payne
David Payne
