Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
Laptop to access printer wireless
I have a PC with a HP printer connected with a cable and this same PC connected with a cable to a DSL ATT modem and this modem is also wireless so my Laptop can get enternet. How can I get my Laptop to work with the printer not being connected to it from another room.
First, can your labtop see your other computer on the network. If it cannot see the other computer you will not be able to print from your laptop. I had a lot of troublel with this until I purchased a program called Network Magic from www.purenetworks.com. It was easy to install and made setting up my network and shared printers easy. It cost $30.00 and is worth every penny.
Posted on Mar 19, 2009
Hp officejet 7310 all-in-one printer wireless connection
reset the printer .
and start over in the manual.
no PC stated,
no statement of what works and what dont ,togethe
do you have a router, ? if yes is it theres or yours?
seems call them get teh unstated laptop working first.
first with ethernet cable, that must work first.
ask them , if its their router and their modem.
if all that is yours, your hardware, then you need to tell what it is
first to get connected. make and model..
i guess you now have cable modem.
to get the router working it needs to be setup to the new cablem modem turning off all DSL modes, and using direct mode.
the printer is here.
for any setups , and resets , are all there. to read.
https://support.hp.com/us-en/product/HP-Officejet-7300-All-in-One-Printer-series/391181/model/391183
Sep 30, 2017 | HP Officejet 7310 All-In-One Printer
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
How to make my laptop as a wifi device so that i can use internet on my mobile by turning on wifi in it??
You can't use your laptop as a wireless router.
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jan 30, 2012 | HP Hewlett Packard 6535b AMD X2 Dual Core...
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
I have a gateway M675 portable desktop w/wireless to a gateway router WGR200. Recently could not access internet (dsl) so purchsed new modem from ATT. Now I have internet access when modem is plugged into...
Yes. You need to configure the router. Most of the new routers come with a cd that will guide you. You can also call ATT and they will guide you as well.
Hope that helps you.
Regards,
Sep 01, 2009 | Gateway M675 Laptop
I can't connect wirelessly with my printer since I got Uverse
i work for att tech. support .. but for DSL
yeah we dont configure printers....
but what you can do is go to the modem interphse
URL....only type in 192.168.1.254 ENTER
and go to FIREWALL then SETTINGS
select DMZ modem or allow all applications
give that a shoot might help.
then see under HOME NETWORK if you see the printer
Jun 21, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Need router or modem for ATT DSL 6.0
Your laptop has got a modem built in, but it is intended for dial up 56Kbps, not DSL. So they are both right. But if you want to use a DSL internet service you will need to buy either a DSL router or modem. You should not need to buy bothas the router will have the modem built in. Your ISP may have a prefered model and will probably sell you one at a fairly cheap price or you can get one from your local PC world. If you only have the one Laptop at home you can buy either the router or the modem. The modem will probably be cheaper. But for around $60 you can buy a router I prefer wireless. This will allow you around 4 connections and more importantly frees you up from having to be directly and closely connected and allows you to work in various places around the home without trailing cables everywhere. Your ISP will advise you on the settings you require. I advise you to enable all the security options on any wireless devices. I hope this was useful.
Carrie
Jul 21, 2008 | Computers & Internet
Help please
you can go to any wi-fi locations near your area and access the internet on your laptop. I think AT&T offers wi-fi access to its members on any of its designated hotspot /wifi locations (nearly 15,000 company-owned & roaming) e.g. McDonald's, Barnes & Noble bookstores, leading airports, coffee shops, etc. you can visit att.com and login to your account to find more details.
or call them at: 1-888-888-7520
you don't need to install any software/ dsl installation on your laptop when you are using a public wi-fi connection, just ensure that your computer firewall is on and take precautions when sending out any personal info online.
Apr 30, 2008 | AT&T High Speed DSL Modem
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
79 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
