Question about Gateway MT6840 Notebook
Gateway MT6840 Laptop will not power up
The laptop is 18 months old, and has been working fine. The other day it was plugged in and my wife opened it up. The screen said that the last time it was turned off it was not done right. She pressed the button for start in safe mode, and everything shut down. The lights on the front do not turn on. We live overseas working for the Navy and there is no support over here.
  • 3 more comments
  • tissierb Jan 15, 2009
    I already tried that. I am trying to verify that the power supply is still good. I opened the back and didn't see any burn marks or breaks in the board. As far as I can tell the power jack is not loose either.
  • Anonymous Jan 26, 2009
    pretty close to the same issue here. Worked one day then the next tried to boot it and it beeped a couple of times. Does not try to spin the hard drive or fans. Blinks a single light on the touch pad 3 or 4 times then nothing. Just sits there.
  • dokchot Apr 05, 2009
    My problem is my MT6840 wont boot up, but it still have power.When i tried to reformat it still saying "Setup cannot find any hard disk drive. Is there anyone can help or solve this?
  • Anonymous May 25, 2009
    help
  • flady_98 May 11, 2010
    Did that power cord has power, battery fully charged.
    Problem Solver:
  • 13 Answers
Remove the battery, attach the power cord and try again.
Posted on Jan 15, 2009
  • David
    David Jan 15, 2009
    If you have a volt meter you can definitely eliminage the power cord as the problem.
2 Suggested Answers
  • 31 Answers
SOURCE: Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Posted on Jun 02, 2009
Gateway MT6840 won't power up
before checking ur mother board check for ur operating system.
Mar 08, 2012 | Gateway MT6840 Notebook
Is there a docking station for my mt6840 gateway computer?
I do not believe there is a docking station for that model. But... Try pulling out the battery. Then plug in the power supply and see if you can get it to power on. If so wiggle the plug and see if it shuts off. If either if those are true, en you most likely need your DC Jack replaced. You would want to take it to a laptop repair shop. It is usually $20 for the part and around 1.5 - 2 hours labor for the repair. Requires pulling out the motherboard and desoldering the old jack. And soldering in a new one. No fun
Dec 12, 2011 | Gateway MT6840 Notebook
Hi I have a Gateway MT6840 laptop. The problem I'm having is it won't run or charge a good battery. I have borrowed a friends Gateway MT6840 laptop to test it and my battery charges and works great in his...
Are you sure that the charger is working?
If not it could be the battery slot. There is nothing you can do on your own except swap batteries ant try.
Mar 03, 2011 | Gateway MT6840 Notebook
What model DVD/CDRW drive do I need for my Gateway MT6840 laptop?
Gateway Part Number: 2527904R
GATEWAY MT6840 8X SUPERMULTI DVD DRIVE> try this one.
Mar 29, 2010 | Gateway MT6840 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Gateway mt6840 new battery will not charge. New charger too. Bad charging port? Bad charger board?
check the connection between the battery and the unit and clean them good try to use elctronic cleaner
Sep 08, 2009 | Gateway MT6840 Notebook
Power port for gateway MT6840
First easy check is to stick a toothpick into the jack to see if the middle pin is loose. If it's not loose, try another power adapter to check just incase. If you dont have one ask around to borrow a universal one. Dont jiggle and wiggle the plug with the power plugged in if it is loose because i've seen shorts happen.
usually plugs are mounted onto the mainboard. To get to the main board, you'd have to take apart everything because everything attatches to the main board. The case, keyboard, heatsinks, speakers, and so on must come off before you'll be able to see the power jack. With parts and labor, it comes close to a new laptop.
Jul 29, 2009 | Gateway MT6840 Notebook
Laptop not charging even when plugged in- battery or power supply
Sounds like you have a bad power jack. Broken solder connection on circuit board. Is it loose when you plug it in the back of the laptop?
If so that is what it is, seek professional repair as it is not a repair for the novice!
Jul 05, 2009 | Gateway Computers & Internet
How to remove the case on gateway mt6840
Have you taken a laptop apart before?Easy to break something but you can do it.go to gateway.com/support and you can dowLoad the instructions. this should solve the problem.RICHARDM69
Jun 05, 2009 | Gateway MT6840 Notebook
Jun 02, 2009 | Gateway MT6840 Notebook
Gateway MT6840 Notebook Logo
1,576 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
