Question about Car Audio & Video
High x-max vs. high sensitivity
Years ago i had a 15" JBL subwoofer in a ported box in the rear of a camaro. It was running off a rockford fosgate punch amp and was receiving 200 watts rms. This set up worked great and was able to hit 133db with this basic installation. The sub only had a "x-max"of 8.5 mm but had a sensitivity rating of 97db.
My question is this----There are a lot of subs on the market that have a high "x-max" rating of 20-30mm yet have a low sensitivity of 85-90db.If you had 2 choose between the following setup,which would yield the highest bass output and spl in a ported box.>>>A)-15" subwoofer receiving 300-400 watts rms."x-max"-12mm,sensitivity 98db.>>>B)-15" subwoofer receiving 300-400 watts rms. "x-max"-24mm,sensitivity 87db.
Would appreciate any input from anyone out there, especially all the "bassheads"
  • 15,935 Answers
Sensitivity is a representation of efficiency. The higher the efficiency, the better the sound quality.
Xmax is a measure of the "throw of the cone peak to peak. This is a direct representation of the volume of air the subwoofer will displace..
A High X.Max subwoofer will displace more air - and therefore produce more SPL in a vented enclosure.
Sensitivity on these subs aren't crucial, because the customer is looking for LOUD and will purchase a large class D Mono amplifier to power it - characteristically low in sensitivity as well due to the way the power is inverted. Highly efficient, yet low sensitiviy.
I am definately a basshead! My show car has (4) 15" Cerwin Vega Stroker PROs. (one of the most highly EFFICIENT high xmax subs available) (86dB). (36-44mm Xmax (adjustable for SQ or SPL)
High x-max vs. high sensitivity - ea141e4.jpg If you are looking for SPL, High XMax, Low sensitivity, and lots of power is the way to go. Generally, to increas SPL by 3dB, yuo must either increase surface area of driver 2x or double the input power. Slot ports, aeroports, and loaded horn ports can also increase your dB level by up to 3dB as well.
Properly constructed enclosures have an effect as well. Instead of wasting some of your power on vibrating the enclosure, it should be braced properly to reduce the wasted energy.
All of these tips will add tou your satisfaction of the product. You can make a $100 sub sound phenomenal in a proper enclosure, and a $400 sub sound like $hit in a prefab or poorly constructed one.
Your original question - with all things equal except the subwoofer, the subwoofer with the higher Xmax should yield the most SPL - due only to the fact of air displacement.
If you have additional questions or need clarification dont hesitate to ask.
Posted on Jan 15, 2009
  • 1 more comment
  • BassMutt Feb 12, 2011
    Pure Bs , using speakers with high sensitivity will require less power to achieve higher volume.
    The total SPL is limited by the Number of drivers and the available space, If you wanted to go higher than 133dB you would have to add more Drivers. If you had a pair of drivers rated each at 96dB it would take around 400 watts to reach 130dB.......thats inside a small to med car, the cabin gain adds some SPL. A pair of speakers rated at 86 dB would require well over a 1000watts to reach 130dB.......Cone excursion at 400watts= 9mm, Cone excursion at 1000 watts = 26mm , so you can see both systems will both reach their xmax and power handling and still get the same SPL. The big benefit of using high Xmax drivers is clean, tight accurate bass at " normal " listening levels......If you want high SPL you need high SPL drivers...and a high spl driver will have less xmax, so more likely to hit distortion, if you still want high SPL and low distortion you need to use more drivers....such as 4 instead of
    2 speakers, each at 97dB with 400 watts = 127 dB with cabin gain 130 to 136dB
    4 speakers, each at 97dB with 400 watts = 131 dB with cabin gain 134 to 140dB
  • adam eldridge Jan 09, 2012
    yur right and wrong 2 10'' subs at 400w rms = 146.7 db learn how to install before u act like u know sumthin i have beatin 2000w multi driver systems with a mere 600w on a single sub rightn now im running a 50 dollar kicker with a 300 w amp and my dbs are touching 129 and thats country music but yes higher eff. levels equal more db with less power
  • amoctez2
    amoctez2 Apr 16, 2013
    You add 6dB when you double power(dB is measured as ratio of powers not voltages!). But at high powers, efficiency is lowered (the nonlinearity depends on the sub you are testing). Therefore, all those theoretical calculations just give approximations. There's nothing like measuring at the resonant frequency.
At high levels sounds more like a thump than boom
Make sure the GAIN on the amp is not all the way up it is not a loud button. your amp should be tuned to your subs with the GAIN or on some LEVEL. if they are not matched you will clip the amp and subs and blow them.Is it in the proper sized box? is the amp able to run the sub at the ohm it needs to be run at and do you have the the ohm load correct on the sub. there is a lot to it. if your not familiar with it go to youtube and watch some videos there is some good vids there and will help you learn to wire a sub correctly i have enclosed a link easy to use.
Rockford Fosgate Woofer WiringWizard
Mar 07, 2016 | Rockford Fosgate Car Audio & Video
Rockford Fosgate Power 1000 amplifier. (25 to life) When I turn it on there is almost no sound coming from speakers. I have to turn up the volume almost to max to hear something. But only very high...
turn or flip the LPF and sub sonic buttons to see if they will help.
there are other buttons called gain that you may have to turn to bring up the volume.
its very likely your eq buttons that you have to mess with to get it right. post up pics if you can.
Nov 02, 2013 | Rockford Fosgate Car Audio & Video
I have two 12" kenwood KFC-W3003 (svc) 4 ohm 600 watts max 160 watts RMS subwoofers and two 12" Rockford Fosgate Punch RFP-4812 (svc) 8 ohm 400 watts max 200 watts RMS. I was wanting to know how i...
It can't be done unless you choose to include some power resistors in your circuit for impedance matching. The problem with that would be some of your power will be lost in the form of heat across the resistors without the benefit of contributing any sound.
Also, the amplifier's damping factor will be compromised, so you may notice a loss in sound clarity. It's possible that you might not easily tell with subwoofers, depending on the enclosures they're mounted in, and whether they're isolated in a trunk vs being in the same airspace with you (hatchback, SUV, or pickup truck).
Nov 13, 2017 | Rockford Fosgate Car Audio & Video
When my bass hits, my car lights flicker.
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
Aug 20, 2009 | Rockford Fosgate P112-200 Car Subwoofer
Rockford sub squeaks
Hello markwasicki,
You did not specify what type of enclosure the subs are in or if they share the same airspace. But the sound you describe sounds suspiciously like the enclosure is at fault and not the sub itself.
Remove and reverse the subs in the box and test for the noise again. If the noise is still produced on the same side of the box, it's the enclosure. If the noise follows the sub, then you have a problem with that sub.
If the box is making the noise, and it's a ported box, you probably have "port noise". If it's a sealed enclosure, you could have either an air leak or flexing noise. In either case, repair the enclosure or put the subs in a new one. If the sub itself is making the noise, there probably isn't much you can do. Most likely some part of the voice coil assembly is touching where it should not.
Hope this helps.
Apr 18, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
Bridge jbl gto 600.1
it will over heat the amp posibly blow it.....becareful
Nov 09, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Car Audio & Video Logo
1,828 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
