Question about AudioBahn A8000T Car Audio Amplifier
Audiobahn A8000T has power but is not hitting
Recently the power wire running from my farad cap to the main power on the amp came disconected, the wire had worked its way out of the ring terminal clamp, I fixed this problem and no more than 1/2 the day later.....I get power to the amp, but it is definately not hitting, no boom boom! :( Please help me
  • 26 Answers
Check your cap, it prob went bad. That could be restricting the power flow now. Try it with out the cap. that just might be the prob.
Posted on Jan 29, 2009
Amp powers up,but get no sound,and protection light comes on
wire are not corrected properly or it touches each other
Apr 27, 2011 | AudioBahn A8000T Car Audio Amplifier
I have an a8000t amp with the protection light on, is the amp broke?
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
-david
Nov 09, 2010 | AudioBahn A8000T Car Audio Amplifier
My A8000t amps red protection light is on checked
When ever the amp stays in RED protection mode with out any speakers hooked up to it, YOUR amp has internal damage some where. Can't tell you how much to fix, Could be cheap or not worth it. Talk to your local electronic repair, would be a good start.
May 14, 2010 | AudioBahn A8000T Car Audio Amplifier
AMP.... question
12vDC
CFM is negotiable - as the higher RPMs the more air it moves. (also louder).
Audiobahn is out of business - and unless someone is willing to tear theirs apart for your info - get whatever they have in stock :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
I conect the amp but its not on
make sure your ground wire is connected securely to bare metal
Mar 22, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Amp has power, but nothing going to subs
did you check on the 'remote' terminal? It should have a +12 vdc to let the amp work. You can check this with a voltmeter. Or might be in 'protection mode' (speaker cut-off relay).
hope this helps
Oct 16, 2008 | AudioBahn A8000T Car Audio Amplifier
AudioBahn A8000T Car Audio Amplifier Logo
93 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
