Question about Lexmark X500n Color Laser All-in-One Printer
Warning: CPU Fan is Lock in lexmark X502 - Lexmark X500n Color Laser All-in-One Printer
  • 1 more comment
  • ftcnet-ca Mar 19, 2009
    .. you need to replace the 24VDC fan on the controller board (on the side of unit, remove the screw above the AC power plug and screw that holds the metal cover). Lexmark claims they can't sell just the fan.
    The fan markings show:
    Y.S. Tech
    DC Brushless Fan
    FD245010MB
    DC 24V 0.10A
    made in china
    If you find a source, please let us know.
  • Claude Klod May 14, 2013
    A suitable replacement for this fan is available. The Sunon replacement is superior to the original fan.http://www.ebay.com/itm/Sunon-50-mm-Ultr...
    A good replacement is available now on ebay. This fan is exact size and has superior performance to the original.http://www.ebay.com/itm/Sunon-50-mm-Ultr...
  • 4 Answers
Www.cypower.com has these fans on order and will be available shortly to be ordered on their website. Just enter FD245010MB into the part number search.
Posted on Apr 23, 2009
  • timr606 Jun 23, 2009
    We have these fans in stock YS Tech FD245010MB Follow the link below to purchase
    http://cypower.com/SearchResults.aspx?ac...
  • buddha358 Apr 19, 2011
    I have a temp fix:
    Take fan out.
    Take off the sticker on the fan.
    Spray a little WD40.
    Don't spray while in the printer! The fan is pretty east to get out. First screw above the power adapter, take off that panel. One more screw after that. It should keep it going till the replacement comes in.
  • 3 Answers
I found the right fan and repaired my machine. If your machine still needs repaired, please let me know.
Posted on May 19, 2013
Lexmark P/N 40X0410
Posted on Mar 04, 2011
RESET FUSER X500N
Here's an article found in the Lexmark website on how to reset the the Fuser page count on X500/X502. Just click on this link: http://bit.ly/aCr2dx. Hope this helps.
Jun 04, 2010 | Lexmark X500n Color Laser All-in-One...
Reset replace OPC belt
Here's the link on how to replace the Photodeveloper Cartridge on the Lexmark X500/X502: http://bit.ly/bzQQtH.
Here's the link on how to reset the photodeveloper (OPC) count on the X500/X502: http://bit.ly/9BxHqz.
Hope this helps.
May 25, 2010 | Lexmark X502N All-In-One Laser Printer
CPU fan locked
Wow, after hours of searching I found the right connectors for the fan since it comes with bare wires when ordered from cypower.com.  (The fan to order is a 24v DC Y.S. Tech FD245010MB.)  The connectors are from JST America and can be ordered from www.digikey.com.
Part 455-1126-ND (housing that takes pins spaced 2mm apart)
Part 455-2148-1-ND (pins)
You have to order at least 10 housings and 100 pins but all of that costs about $2.50.
You can also order the crimp tool but that costs $1,300.  I'll just use a needle nose pliers.
Oct 20, 2009 | Lexmark X502N All-In-One Laser Printer
My Lexmark 500n has a warning message [ WARNING: CPU Fan is Locked ]what does that mean?Seems to print fine but the message is ;( Anybody know what I should do?
Might be some foreign debris stopping the cpu fan from running and cooling the cpu.
I wouldn't leave this problem for long since a fried cpu will mean the end of your printer
Sep 27, 2009 | Lexmark X3550 All-In-One Printer
Double side priting in lexmark X502
in Lexmark X502n you can not do a duplex print as in print both sides which is actually a big surprise because overall its an amazing printer.
Go on this website and at the bottom you'll see that it has no duplex printing:
http://www.lexmark.com/lexmark/product/home/735/0,6970,204816596_653293760_1043815135_en,00.html?tabId=1
Jan 21, 2009 | Lexmark X500n Color Laser All-in-One...
Warning: CPU Fan is Locked!
You have a fan that is not working.
Just be happy that is isn't the photoconductor.
What kind of computer is it?
If a fan isnt working it is not the end of the world,... Front fans go all the time and are basically useless anyway.
If it is hampering our ability to print lemme know and I will delve further into this.
I will need the make and model of the computer/printer.
Jan 15, 2009 | Lexmark X500n Color Laser All-in-One...
Warning: CPU Fan is LOCKED -- Lexmark X500n printer
I fixed this in 12 minutes. I took the fan out, lubed it up with a high-tech petroleum based lube and freed up the fan. Reinstalled and no more error message. We ordered a new one so when this fails, we'll be ready. It seems that moisture got into the axle and corroded it and caused it to lock up.
Jan 06, 2009 | Lexmark X500n Color Laser All-in-One...
I have a technics su x502 amp & it works for a while then goes off & then comes back on after about 5 mins,the rest of hifi stays on its just the amp.
take out the cooling unit (the fan) and use a cpu fan out of a pc connected to an external power source like a 12v dc/ac adaptor and use it to blow constant cool air through the hole onto the heat sink. i know it sounds like a ruff job but it does work, my amp doesnt even get hot and it plays all night long without cutting out once. you will get noise from the fan constantly on but i just turn it up louder. this is just a ruff quick fix.
Aug 09, 2008 | Audio Players & Recorders
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Lexmark X500n Color Laser All-in-One Printer Logo
2,379 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
