Question about Carl Zeiss Diascope - Spotting scope 85 T* FL - roof
Sony, carl zeiss, vario tessar op3x, 7,2mgp
How can i dawnlod music into my D camera?
0 characters
1 Points
Dont understand why on top of an side of scope setting there is ur ur instead of left right or up down
The "U" indicates Up on the elevation dial, and the "R" indicates Right on the windage dial. Turn the elevation dial clockwise to move the point of impact up, counterclockwise moves down. Similarly, turning the windage dial clockwise moves Right, and counterclockwise moves left. Here's a scan from the Zeiss Conquest manual:
Jan 05, 2011 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
On my ziess conquest, what turning knobs do what? which one makes it go up and down and which one makes it go left and right?
The top knob should be marked with a "U" and an arrow pointing clockwise. Turning this knob clockwise should adjust point of impact Up, and turning it counter-clockwise should move it Down.
The knob on the side should be marked with a "R" and an arrow pointing clockwise. Turning this knob clockwise should adjust the point of impact Right, and counter-clockwise is Left.
Nov 09, 2010 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
I have a Winchester 7600 from the late 60's that I have never fired. I have just stored it here at home and never really had a use for it. I do not even know what type of ammo it takes. Can anyone tell me?
I think you will find that you have a Remington 7600 pump action rifle chambered in a Winchester calibre round. There may be something inscribed on the barrel with Winchester on it. The numbers with the word Winchester EG: .308 will denote the calibre. Just like a .38 revolver will have .38S&W on it regardless who manufactures it. The name S&W indicates the original patentee of the round. So your Remington 7600 is chambered for a Winchester patent round. The number with it such as 308 or 243 will tell you what ammo it takes.
Aug 01, 2009 | Zeiss CONQUEST 4.5-14X44 AO MATTE Z PLEX
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Zeiss diascope coarse adjustment
sounds like you lost the locking Allen screw.
need that to sort your problem.
Jul 11, 2008 | Zeiss 528013 / 528015 Diascope 85
I have a Kodak camera with a lens adapter that has 55 mm threads. How do I attach the Meade 64t-adapter to it?
Try a photo shop to see if you can get a T-adaptor to fit your camera (this is for SLR cameras without lens attached - the telescope becomes the lens)
But if you mean the 55mm filter threads, ie with the lens still on the camera, then you have the wrong thing. You need instead a contraption that holds the camera in position to take photos through the eyeepiece of the telescope (ie both telescope eyepiece and camera lens remain in place). With non-SLR cameras, that is the way to do it.
Apr 18, 2008 | Meade ETX-90 (48x90 mm)
Crosman airguns 357 6 shot
What part are you having trouble with?
I have had mine apart several times trying to repair a leaky valve.
Could possibly make a you tube clip.
Dec 26, 2007 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Zeiss 3 x 9
Gusbear, here is the whole shebang. document.write(mdec('c#6#8#9#5m#3r#0#8#3rv#7c#3#1v#7#8#7#5#4#0z#3#7#8#8#0c#5m')) this is for their sandiego offices
Carl Zeiss Optical, Inc., Chester document.write(getAddressCountry('US','USA')) document.write(t_phone) Phone: +1 800 441 3005
document.write(t_fax) Fax: +1 804 530 8333 form.gif document.write(t_inq) Inquiry
email.gif document.write(mdec('#8p#5r#9#8#5p#9#7c#8#1z#3#7#8#8#0c#5m'))
this is for the sport optics contact you are looking for. give them a ring or drop a line, they should be able to help you out.
Dec 01, 2007 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
I hunt in Wyoming so I understand your dilemma. I recommend using running tap water to take off the clay and mud. Let dry and repeat if you need to. That will allow the bonds the clay and mud have on your scope to loosen and fall away between rinses. This will save your scope's finish. When you get ready for your lenses take extra care! I use ammonia free towelettes i get at the local electronics store to leave a streak free shine on my lenses. Using ammonia or alcohol will break down and ruin the fog proof and water proof coatings you can enjoy with your optic now. Otherwise that's the best recipe for getting your optic back to 100%
Nov 26, 2007 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Carl Zeiss Diascope - Spotting scope 85 T* FL - roof Logo
313 people viewed this question
Top Carl Spotting Scopes Experts
Michael Thomas
Michael Thomas
Are you a Carl Spotting Scope Expert? Answer questions, earn points and help others
