Question about Nintendo DS Lite Console
Nintendo ds lite charger
My dog chewed through the cable in my ds charger and i thought it would be a simple fix by just stripping the wires and re-connecting them....but for some reason its not working...this is the 3rd charger the dog has chewed through and dont plan on buying another one... was wondering if anyone had a rough idea of what i should do or what is causing the power to not go to the nintendo ds.... thanks in advance
  • 3 more comments
  • lucas_jacob_ Jan 15, 2009
    thanks xbox360fixer
    inside the cabe it appears what would be a positive and a ne
    gative cable (im assuming) there's a main copper wire (red) that is insulated and an unshielded copper wire the wraps around the shielded wire...where the wire was chewed, i stripped both ends and tried reconnecting the two wires but it didnt work...any ideas
    two
  • lucas_jacob_ Jan 16, 2009
    yeh that was the problem... a little bit of copper was touching the positive wire...thanks heaps for the help
  • VIDEOGAME REPAIR SERVICE
    Did you make sure its not touching any of the other wires.
    Just what?? How many wires are inside the cable?
    Problem Solver:
  • 11 Answers
Just buy a new one i use 3rd and 1st party work the same keep it away from your dog
Posted on Jan 15, 2009
My dog chewed my daughters DS Lite's outter shell. There are bite marks and it happens to be on the side where the power button was. Can this be repaired? There is no more power button, otherwise it's all...
if you are good with your hands at fixing things you can give it a go.... you can search on ebay since they have any and every part of each and every game system. just remember not to pay too much for em. one note of caution though. if you open up the system to repair it you will void the warranty.
Apr 29, 2010 | Nintendo Pokemon Diamond for DS
Tip
Nintendo Ds & Lite Standby/Sleep Fix Mod.
What's Needed.
  • -(-) flat 1/32" for removing the rubber sticker near the "L" and "R" keys
  • -(-) flat 3/32" for Nintendo DS skrews (tri-wing skrews)
  • -(+) cross #0 for removing battery cover/slot skrew and "L/R" area skrews
  • Radio Shack .022 dia. Silver-Bearing Solder Rosin-Core
  • Cordless Butane Solder old Wall Lenk solder (whatever works for you)
  • USB Cable white wire (prob any peice of wire will do)
  • box cutter to strip wires (personally hate most wire strippers)
  • scissors to cut wires
[edit]Open the DS
  • Remove the battery cover
  • Unscrew every tri-wing screws with the screwdriver
(Note that pin 1 is actually the second point from the right. If you look closely at your DS Lite you'll see that the one on the far right is not actually connected to the card slot. You can't quite make it out from the pictures, but you get the point.)
--Rion 10:25, 12 September 2006 (PDT)
on Feb 15, 2010 | Video Game Consoles & Games
Why wont my ds lite charge in any of the outlets
if the socket fits in the outlets i guess the wires messed up just try fiddling with the wire it just might work
Apr 17, 2010 | Nintendo DS Lite Console
When plugging in the dsi charger the orange lite comes on for anout 3 seconds then turns off
Maybe It's because it's chewed up (mine was chewed or something so I got a new one... I've been in the same situation, bud, but I couldn't do anything about the copper wire showing underneath.). Make sure to check the entire cord.
1) Try flicking on a power switch.
2) Unplug the actual charger from the wall, and plug it into a different outlet. The outlet you're using may be broken.
3) Make sure the charger is all of the way plugged into your DSi.
Really hope this helped!
Mar 27, 2010 | Nintendo DS Lite Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Clamp is broken on inside of nintendo ds lite
if your dog did it if you have a dog kill it or if it was crushed bend it
Jan 04, 2009 | Nintendo DS Lite Console
Power gone on nintendo ds lite
Hey if you have a warranty nintendo might repair or raplace the Ds.I thought about replacing the charger or place the charger in another power outlet.I hope I helped.
Dec 30, 2008 | Nintendo DS Lite Console
Nintendo ds lite shut down
I would contact nintendo if you have a warranty. Also try changing the battery or charger on the internet
Dec 03, 2008 | Nintendo DS Lite Console
Conection?
Here is a guide to dismantle an original Nintendo2.gif DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video2.gif in youtube: "Disassembling Nintendo DS2.gif Lite"
And after opening it you can do your work. Make sure the flexible cables connecting the top screen part of your DS are well in place and not broken. Your problem may be only a loosen cable but in case the cable is broken you gonna need a replacement. Be careful not to damage the screen or other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
165 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
