Question about Lexmark X502N All-In-One Laser Printer
Warning: CPU Fan is Locked!
I have been receiving this message .. what does this messgae mean? and how to solve the issue
    Problem Solver:
  • 7 Answers
Wow, after hours of searching I found the right connectors for the fan since it comes with bare wires when ordered from www.cypower.com. (The fan to order is a 24v DC Y.S. Tech FD245010MB.)The connectors are from JST America and can be ordered from www.digikey.com.
Part 455-1126-ND (housing that takes pins spaced 2mm apart)
Part 455-2148-1-ND (pins)
You have to order at least 10 housings and 100 pins but all of that costs about $2.50.
You can also order the crimp tool but that costs $1,300. I'll just use a needle nose pliers.
Posted on Mar 20, 2010
  • 3 Answers
You have tor replace the fan.
Order here: henke.harald@web.de
Posted on Jan 11, 2010
Received a messgae from Security Warning that my Facebook account has a virus called koobface. I cannot open my account. Please help me.
Sorry about that,but here's a link that will help you remove koobface from your pc so your friends dont get automated messages from you--http://hassam.hubpages.com/hub/How-To-Remove-Koobface-Virus --if you cant log in,its a different issue, simply ask for facebook password reset and you'll get a new one to your e-mail.
tips for you-- there has been news about hackers trying to steal your FB log-in info.usually, they send you a "notification" "a message alert" that comes along with a link for you to click to address the false issue, and when you click on their links--IT USUALLY ASKS YOU TO LOG IN OR INPUT YOUR INFO BESIDES THE FACT THAT YOU ARE ALREADY LOGGED IN (that is a red flag) i would recommend you ignoring or reporting/flagging the message.
Aug 24, 2011 | Facebook Computers & Internet
I am getting a message on projector that fan stopped. what does that mean?
hi,
ur projectors lamp cooling fan have some problem. if the fan stopped the lamp will get over heated, that's why cooling fan is must. its a warning message if not it will create some problem to ur projector's lamp. u should use the projector only after solving the fan problem.
ok
Dec 17, 2010 | InFocus Office Equipment & Supplies
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
Apr 22, 2010 | Nuvico NVDV3-16000N
AUTO SHUTTING DOWN WHEN LOADING WINDOWS
Hi there!
AMDs (some of them) have Overheating issues. Your default BIOS is set to protect the CPU chip in case of overheating. It will do so by shutting down the computer.
You can hold "delete" key on boot to enter BIOS. Go to "PC Health Status" or " Hardware monitor". Here if you see temperature exceeding 60 degrees or more, this mean it's OVERHEATING!
Now the first thing is to check if your CPU fan is running & is well secured with the lock. Try to move it to see if it's loose. Secure it properly to solve. If it's not running, you'll need to replace.
However if it's not the problem, remove the fan & its aluminum heat-sink with CARE. Then re-seat the heat-sink properly.
Note that a poor contact of CPU & heat-sink = Very Hot CPU & cold heat-sink.
If it's not the case, therefore remove the heat-sink & clean the old thermal paste on it & the Cpu chip also.
Apply proper thermal grease e'g Arctic Silver.
If the above does not solve the issue, you'll need to replace fan. (pls check with another one before buying a new one if possible)
Ultimately if the issue is not solved by the above, this means that the heat sensor on the motherboard is faulty. Here motherboard needs replacement or warranty services.
Hope this advice really helps you. Please remember to send us your valuable feedback as it's very important for us!
Mar 05, 2010 | Biostar NF61S MICRO AM2 SE...
CPU fan locked
Wow, after hours of searching I found the right connectors for the fan since it comes with bare wires when ordered from cypower.com.  (The fan to order is a 24v DC Y.S. Tech FD245010MB.)  The connectors are from JST America and can be ordered from www.digikey.com.
Oct 20, 2009 | Lexmark X502N All-In-One Laser Printer
My Lexmark 500n has a warning message [ WARNING: CPU Fan is Locked ]what does that mean?Seems to print fine but the message is ;( Anybody know what I should do?
Might be some foreign debris stopping the cpu fan from running and cooling the cpu.
I wouldn't leave this problem for long since a fried cpu will mean the end of your printer
Sep 27, 2009 | Lexmark X3550 All-In-One Printer
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
You have a fan that is not working.
Just be happy that is isn't the photoconductor.
What kind of computer is it?
If a fan isnt working it is not the end of the world,... Front fans go all the time and are basically useless anyway.
If it is hampering our ability to print lemme know and I will delve further into this.
I will need the make and model of the computer/printer.
Jan 15, 2009 | Lexmark X500n Color Laser All-in-One...
CPU fan fail or speed too low
I bought the same motherboard this past year (used) and installed it with AMD Athlon 64 fx-57, Antec P180 case, 550 w power supply. I had the case cover off to check the fans when I first fired it up. The AMD oem cpu fan hesitated at power on for a few seconds, which worried me. It started spinning normally and I then shut the system down and waited a few minutes before restarting it. It spinned up fine so I put the cover back on. I started getting the same error you mentioned, so I updated the BIOS to 1013 version. That didn't solve the problem. I ended up disabling the warning in the BIOS as I got tired of seeing it, as I could see the fans were all spinning and the CPU temperature was at about 26 to 34 on cold boot.
I recently checked on this problem and seems many others with this board have this problem. One fellow said he mailed off a question the the problem to ASUStek and they replied that it is just a glitch, that the fan is "smarter" than the BIOS, as it will hesitate to spin fully at start up if the CPU is cool. The suggestion was to disable "Q Fan Controller" in BIOS. I did and don't get that warning.
As for the yellow question marks under manage in Windows, you need to install the drivers for all of those devices, and they will be on the disk that came with the motherboard. I use the latest drivers from the ASUS site, but the only one I couldn't install was the ACPI ATK 0110 Virtual Device that came out in 2007. When I try to unpack the .rar file it says Corrupt Headers and refuses to use the driver from that file. So, I use the driver from the disk.
Apr 12, 2007 | ASUS A8N-E Motherboard
Lexmark X502N All-In-One Laser Printer Logo
698 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
