Question about ASUS GeForce 6800 V9999 Gamer Edition (256 MB) Graphic Card
ASUS GeForce 6800 V9999 board
The power suppy in my pc blew up, all smoking and everything, really nasty, however it only blew the board of my 6800, toasted it, there's a mini crater where pcb and tracks once were. So i was wondering if it was possible to replace the board only, as i have the original heatsink and fan assembly. Thank you for your time
  • 3 Answers
You should contact ASUS and ask them if there's anything they can do. I doubt that it's possible. You will probably have to buy another card. Good luck.
Posted on Jun 20, 2007
SOURCE:
I am having problems with my nvidia geforce 6800 gt. When i turn on my pc everything is fine but whenever i play games for ex. Bioshock or counter strike source my pc screan turns off and says no signal....
i suspect youyr graphics card is heating up and shutting off to prevent damage. windows will also shut it off but usually repaorts that it did. here is my reccomendation:
1. open side case and place a fan right nest to it. if this makes it work then heat is definitely trhe culprit. if so install a video card cooler or another exhaust fan.
2 turn all the graphics options down on the game. shut anti aliasing off and all options to minimun. then try to play if it still shuts off then your card may be on its last leg from over heating. the 6800 gt was ok when it came out but todays games require more. in fact the newer games won't run on a 6800 gt.
the big thing is heat. the standard 6800 gt just doesn't get rid of enough heat. in fact the 9800 gt i had overheated and burned out. i stay away from gt and now use gtx cards. they have a better cooler and ususally the vent outside of the case.
May 15, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
No signal on screen after install the new VGA card
No, you dont need any power to the Graphics card.
But make sure that the monitor is connected to the new graphics card that you have installed and not on the on-board VGA card. That should do it for you !
May 12, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
After I plug in my graphics card it makes a high pitch squealing.
Unplug the board, don't put the side panel on and listen for the sound. Sometime a rolled up newspaper can be used as a stethescope and help determine the squeal location.
Mar 27, 2009 | Nvidia BFG GeForce 6800 Ultra Overclocked...
Is my Motherboard compatible?
Probably not. There is not quite enough information in your post to really help, but from what I'm finding on the GeForce 6800 GT, it is only available in PCI-Express and AGP 8x (AGP3.0) Versions. Your motherboard only supports AGP 1x, 2x and 4x (AGP2.0) cards.
Dec 13, 2007 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
Overheating
add a exhaust fan to your case see if this helps
Nov 03, 2007 | ASUS GeForce 6800 V9999 Gamer Edition (256...
I have Asus P5S800 main board
dr-afacan, You unfortunatley are not giving me a lot of info to work with. There could be several things to try. First check your cases front panel to Board connections. Then if they are correct I would swap out the power supply with anything compatible to check and see. If that PS is really OK. If you do not have the info for the board go here http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e1767_p5s800-vm.pdf
Next step would be to either check the processor, possible BIOS settings or update. Or you unfortunatley just have a dead board. Asus has a good customer RMA system... Just some thoughts.....PCdok
Oct 14, 2007 | ASUS P5S800-VM Motherboard
Flashing poligons
regarded tsakom, that is result of overheating the GPU, you can try 3 of the following: 1 - remove your graphics card and cleanse the fan from any dust or debries 2 - add 1 or 2 drops of wd40 (yes oil) to the cards fan rotor. 3 - add a bigger, fan positioned to push cold ar agains the cards GPU. Preferebly on that shift the ar on and against all the board, and never pulling it out. You cool something pushing cold air against it, never removing the hot air, if you do that, you only fuel the heat even more.
Sep 07, 2007 | ASUS GeForce 6800 V9999 Gamer Edition (256...
Geforce 6800 Xtreme AGP
Have you disabled the onboard Graphics card? Press F2 on startup and disbale the card in the BIOS.
Dec 21, 2006 | Pine Technology GeForce 6800 XTreme, (256...
Open Questions:
See all ASUS GeForce 6800 V9999 Gamer Edition (256 MB) Questions
ASUS GeForce 6800 V9999 Gamer Edition (256 MB) Graphic Card Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
