Question about HP LaserJet 4350 Printer
Hp4350n hello, my LaserJet 4350n printer is networked and working fine. i managed to turn on duplex services manually and worked fine, BUT I want to make it automatically!! so that any one the network can print on both sides. any helper?? Thank you khb09
    Genius:
  • 2,120 Answers
Set it in JetAdmin.
Posted on Feb 06, 2009
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to http://www.hp.com for more information
May 27, 2015 | HP LaserJet 4350n Printer
I have hp3005d printer working fine but can't print duplex ( both sides) printing I am connect through network tcp/ip I have change the setting on the printing properties but still only manual duplex...
Right click on the printer driver icon and select properties. When the window opens, click on device settings tab at the top. Under device settings you will find a section labelled "installable options". Make it that it shows the duplexer installed. This is the most common reason that the duplexing will not function.
Jul 13, 2011 | HP LaserJet P3005d Printer
Auto Duplex Unit Not Working Model: HP LaserJet 2420dn I am using Windows XP and installed "HP LaserJet 2420 PCL 5e" driver. It is connected via internet and when I try to print double...
You need to go into the print driver on your Windows machine and go to the Device settings tab. One of the settings is to set whether the unit has a duplexer or not. It does not always set automatically.
Jun 23, 2011 | HP LaserJet 2420dn Printer
Is this a duplex machine please?
Yes it is.
HP LaserJet P3005n Printer (Q7814A)
Specs:
Duplex printing (printing on both sides of paper)
Yes: Automatic (standard)
Please give me a big thumbs up for my answer, when you rate it. Thanks.
Jan 28, 2010 | HP LaserJet P3005n Printer
HP laserjet 1300n won't print duplex from vista
in the printer driver setting there is option to turn on manual duplex printing.
Go to printer driver properties go to printing default under printing default there is a option called finishing in finishing print on both sides is mentioned select that option and i m sure it should work
May 03, 2009 | HP LaserJet 1300n Printer
Is HP Laser Jet 2420n
Duplex on this printer is manual, that means that you will have to re-insert the paper by yourself.
This if you have the 2420n, the 2420dn instead is the duplex model.
Here specifications, look where it says duplex, 2420n had only manual duplex (the printer wait for you to re-insert page).
Feb 17, 2009 | HP LaserJet 2420n Printer
Renaming networked HP laserjet 4350n printer rename
Restart the computer in safe mode and try and delete the printer. If that doesn't work download the the Kyocera print driver seleter from kyoceramita.com and use it to delete the driver.
Jan 06, 2009 | HP LaserJet 4350n Printer
Hp laserhet p2015d driver duplex driver for Pagemaker
Please download and install the Universal Printing Driver - PS version from the followng site:
If the printer is connected via USB, select the Traditional Mode, if DHCP network, select Dynamic Mode.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845555&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-36004-15
Oct 11, 2008 | HP LaserJet P2015dn Printer
Unable to print both side though requested
as i know, usb-printers don't support both side printing. It is words of the generant
Sep 24, 2008 | HP LaserJet P2015dn Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
HP LaserJet 4350 Printer Logo
113 people viewed this question
Ben Johnson
