Question about Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference
Polycom sound station 2 conference set conference problem
Dear All,
I have a sound station 2 , and my issue is the conference not operate normally ,where if I have an active call and when I made a conference call with this conference sets, we must make mute for listening to other side and if other side need to listen to us he must make mute (one way communication in conference calls )so I need your fast feedback for this issue.
NOTE: I used another system Sound Station but it is working normally , and this issue with four Sound station 2 systems .
  • 93 Answers
Sounds strange, it lookslike a main board problem, considering that u have been using similar unit before.there is not much that u can do from the menu options.u will have to refer ur vendor for rpairs
Posted on Feb 09, 2009
What is the station type to use when hooking this polycom sound station premier EX to an Avaya S8300 on a digital port card?
The Polycon Sound Station Premier coference phone is an analog device. You need to connect it to an analog port on your phone system.
Dec 13, 2010 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
We have an old polycom sound station which is not wireless and does not have the screen. We need to conference with 2 people. I know we can do it with the soundstation 2w but can we do it with the old...
It would depend on if this is going through the phone system, or just a phone line all by itself.
If on the phone system, there should be a conference button, that is like a "flash" button on your home phone.....
Sep 01, 2010 | Polycom SoundStation
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
Feb 02, 2009 | Lands Phones
Conference problem
repeat you setup for all station you want to connect to it.
Sep 18, 2008 | Polycom SoundStation
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Adding person to a teleconference group
How can I add 3 other people on the conference call using a Polycom Soundstation?
Jan 08, 2008 | Polycom SoundStation
Registration Failed
I solved this issue with our Polycom by following the following instructions via the link below.
Upgrade phones with following software:
CVM: Version 1.61
All SoundStation2Ws with software CVM version 1.61 are susceptible to this failure mechanism and must be updated. To upgrade the software, please download theSoundStation2W Software Upgrade application and follow the detailed Software Upgrade Instructions located on the SoundStation2W support page. This issue only impacts the CVM version number listed above.
Requirements:
1. USB cable for the Polycom wireless unit
2. Windows XP machine
3. Download the instructions
4. Download the Firmware Update
Dec 27, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Oct 22, 2007 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Polycom SoundStation 2W (2200-07800-001) Wireless Audio Conference Logo
1,027 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
