OR INSERT BOOT MEDIA IN SELECTED BOOT DEVICE AND PRESS A KEY. I HAVE NOT ORIGINAL SOFTWARE,FOR BACK UP, TO RESTORE. PLZ HOW CAN I RESTORE MY COMPUTER?
It really depends on a couple of things. Try pressing F8 during boot up and disabling auto restart on errors. Usually this will give you an error code that you can look up online and find the solution. If that does not work try pressing F8 again during startup and try booting in safe mode, if it allows you into safemode then it is probally software related and a restore will work. If it will not let you into safe mode then it is probally hardware related. Try pressing F8 during boot up and select safemode with command prompt; if it allows the command prompt up type chkdsk /f This will check the ard drive for any errors and attempt to fix them. Once it is done it will reboot the pc. If that does not work you should try replacing the hard drive. Good Luck Hope I was Helpful.
Hi
the problem wont be solved by restoring you r computer.......... check cables
I have the same problem, i have a black screen and it displays the same as dandygal above. I also do not have the booting disc. Can someone please help!!! Also, does anyone know if I will be able to save my files?
