Question about HP Pavilion dv4000 Notebook
My laptop switches on shortly and then off
Water was poured in it ,that is when it started behaving like that. so what should have gone wrong?
Hello
Posted on Jan 15, 2009
Water was poured on my laptop and it went, I have tried to switch it on but it is not coming on
It seems like there is some short circuit on the board so all you need to do is to take everything apart and clean your laptop using isopropyle alcohol.
Oct 01, 2013 | Computers & Internet
Water pours out from washer
Most washer i know of have a small hose coming from the base of the tub abd going up to a water pressure switch up in the controls. As the water level rises the pressure inside the tube rises. When the water level gets just right the pressure inside the switch kills the water and starts the motor. So what goes wrong? Trash and sediment such as sand gets into the tubing. Removing the tube from the control and blowing it out in most cases fixes the probo. Note: If you do this you need to pump out any water in the machine before you start another wash cycle. So that the pressure will build once again in the tubing and shut off the washer at the correct fill.
Sep 04, 2013 | Washing Machines
My Hoover First Edition keeps filling with water to the point of it pouring out of the door. It seems to be draining fine, but just keeps letting in short bursts of water, which don't seem to stop. ...
This seems quite likely to be a fault of the WATER LEVEL SENSOR. So since the pressure activated switch is not working even when the set water level is reached the water overflows.
Drain the water out of the washer and remove the level sensor which is located on the rim of the drum which has a tube feeding water to a pressure activated switch- the diaphragm could have punctured or failed on the switch.
You can bypass the switch by shorting to see if the machine starts and works , if so change the switch.
May 18, 2011 | Hotpoint First Edition FEW12 Front Load...
It recently started flickering when I turn it on. It did this for several minutes before displaying normally. Then it wouldn't display anything at all until I turned it on and off several times. Then it...
duffy325, Don't mess with it!!! Get SAMSUNG to give you a new or REFURBISHED unit t0 replace your BAD unit. Your unit is behaving like I would expect a 3-5 year old unit. It's got a power supply problem, not a front panel switch gone bad problem. FYI also visit YOUTUBE for the longer video clips of "LCD monitor disassembly" and "LCD monitor repair" to find out some common KNOWN failure mechanisims why they fail!! You will be amazed! With your unit's behavior I suspect a "flakly backlight or SMPS/INVERTER" problem. bye for now. If this was of some help, do rate this response on fixya. 12fixlouie
Nov 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
1994 suburban gmc - no start in heavy rain or high humidity
When was the last time the truck was tuned up? sounds like there is a hair line crack in the distributor cap witch in turn lets moisture get in there and it won't start until it dries back out, the heat from the hair dryer is most likely drying out the moisture in the cap seeing its so close to the throtel body. Do a tune up.
Jul 14, 2009 | 1999 GMC Suburban
Doesnt stop pouring water
it is suppose to turn off, bad fill valve.
Nov 08, 2008 | Washing Machines
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
Laptop is not booting and beep three time
i have this problem... my laptop still doesent work but to switch it on just rap it in towels or clothes or even put under ur pillow and leave it there for half an hour keep on doing this and it will switch on thanks
May 04, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How to drain liquid chlorine?
Get as much as you can out with a towel, then flush the rest with cold water. Just pour it in and dry it out with a towel until you are able to pour water in it and it go out the dispenser like normal. After you have gotten the dispenser cleaed out you will need to get the detergent out of the machine before using it. Start a cycle with cold water. Let it start washing, when you see suds forming pour in a little vegetable cooking oil. This will kill the suds. Keep doing this through the cycle. After the suds are gone and the cycle is done, run it through another cycle with hot water. If you have no suds you are done. If It still suds up by the end of that cycle, run the cold wash and vegetable oil again.
You should be ok by running one cold and one hot, just watch it and add a little oil to kill the suds.
The cooking oil trick works with dishwashers too if you ever put the wrong detergent in them.
Please reply if you need any more help.
Oct 23, 2007 | Kenmore Oasis 27042 Top Load Washer
HP Pavilion dv4000 Notebook Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
