Question about HTC Tilt 8900 Smartphone
Software and mechanical problems
I erased my HTC Home because it wasn't loading....now what do I do????? Also I'm having problems with the contact points of the USB in the phone. I have to juggle the charger around to make contact.
  • 19,396 Answers
If the phone starts up, then you need to download re-install the HTC Home software.
See:
How to Download the HTC Home Plugin
HTC home plugin v2.1 freeware
YouTube - How to install HTC home
Posted on Jan 15, 2009
    President:
  • 2,110 Answers
Try to use another usb cable...which is easily available in market...
How to unlock screen, when code number is lost?
Reset LG G2x P999 to Restore Factory Default Settings
How to hard reset (factory reset) the LG G2x P999?
There are two different ways you can reset your LG G2x P999 to its factory default settings, via settings menu and using phone buttons. WARNING!!! If a factory reset (hard reset) is performed, all installed application and user data such as messages, phone contacts, image, video and audio files will be erased. Please remember to back up any important data before performing a factory reset.
Reset LG G2x P999 using Settings Menu
  1. From the Home screen, press the Menu Key .
  2. Touch Settings > Privacy > Factory data reset.
  3. Read the warning and touch Reset phone.
  4. Touch Erase everything.
Reset LG G2x P999 using Phone Buttons
  1. Turn the power off.
  2. Press and hold the following keys at the same time for 15 seconds: Home Key+ Power Key + Down Volume Key.
  3. When the LG logo is displayed, release the keys. The phone will turn on and
    perform a factory reset immediately.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card.
Mar 26, 2015 | LG G2x / Optimus 2X 4G Android T-Mobi8GB...
Lost everything except my contacts. How can I get my pics back?
Unless you had a SD card or Had your pictures saved to like Gmail or something then you have lost all of your pictures.
Mar 28, 2013 | HTC Cell Phones
I can't turn on bluetooth for htc hd2. it said" Error in loading the Bluetooth stack (oxi)
Hello Tuy,
It seems that you have to update the software of HTC HD2 Smartphone. HTC provides Rom Upgrade in which it completely replaces the built - in software in the phone. Rom upgrade in the HTC HD2 Smartphone extends its features, imroves its performance which makes it easy to use.
Download the Rom Upgrade from the link provided below :
http://www.htc.com/www/SupportDownload.aspx?p_id=297&cat=2&dl_id=856
Rom upgradation completely erase the personal data and the customized settingsor any installed programs in the
HTC HD2 Smartphone. Before Rom upgradation pleas backup all your data.
Please visit the below links to backup your data before upgradation :
http://www.htc.com/www/howto.aspx?p_id=297&id=191
http://www.htc.com/www/howto.aspx?p_id=297&id=187
During ROM upgrade, make sure that your phone battery is at least 50% charged. Automatic standby and hibernation are disabled in computer, and close all running programs. Do not disconnect your
HTC HD2 Smartphone from your computer while the phone software is being updated. If you disconnect the HTC HD2 Smartphonee during the software update, it may become unusable.
Jun 05, 2011 | HTC HD2 Smartphone
When i exit a app and go to home i get a white screen that says htc and then it starts to reload. how do i fix it?
Try this: From home screen touch menu then go to settings then privacy then factory data reset and finally reset phone. This will reset you phone and prompt you to activate it when it starts up. This will erase all of your apps but not your contacts as they are sync'd with your Google account. This should fix your problem unless it is a hardware issue. If it is indeed a hardware issue take it to Verizon.
Mar 05, 2011 | HTC Droid Incredible Cell Phone
Keep getting com.HTC.launcher has quit working. Will not load home page.
hi grfdadam . First take your battery oput of the phone let do a soft reset on the phone. Next you have to make sure you have all the information when you first activate te phone. If you see that your phone is still not working . Their is a reset button on all htc phones. Now yuid will erase ll your information on the phone. You will have to reactive and reset up evertyhing on the phone. Now you could go to htc's site and check to see if they havea soultion for this problem. I can only tell you what to do but htc knows their phones and if they are see a problem on a regular bases and what fix they have. I hope this little bit of information helps
Dec 06, 2010 | HTC Hero Smartphone
When I open it it has black screen only what might be the problem with it? do I need a new LCD? My HTC model is Touch HD
you can try this if its software problem then it can get solved and if you are from Gujarat then i can help you in solving the problem if your phone is in warranty then just send it to company you may contact me on aniruddh11@gmail.com
just hold on green and red button and switch it on problem solved
caution phone memory erased
regards
aniruddh
May 25, 2010 | HTC Touch HD Smartphone
It says, "the layout you have selected cannot be loaded. please select a different layout using the home screen items in settings." When you got there, there is no window deafualt or anything
And you can't change the homescreen in settings, correct?
Your going to have to perform a master reset. This will erase all your third party software, notes, etc.
  • Press and hold both soft keys and power the device on.
  • The screen will go black. Just press 0 when it asks.
  • Hope this helps,
    BReady
    Mar 27, 2010 | HTC 3125 Smartphone
    Home plugin
    Hi
    I have a HTC Phone. I have installed the software in my laptop too, but i am not able to copy my contacts to laptop.
    venkat
    Aug 24, 2009 | HTC Touch P3450 Smartphone
    Slow start up and touch screen not working
    HTC Canada walked me through a hard reboot - green+red key + reset key. This is erase everything on the phone, but it will then work. Then got to htc canada website and download the windows update which solves the freezing screen problem.
    good luck - it worked for me.
    Jul 25, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
    HTC Tilt 8900 Smartphone Logo
    54 people viewed this question
    Top HTC Computers & Internet Experts
    SANJEEV KUMAR SURI
    SANJEEV KUMAR SURI
    Tom Chichester
    Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
